Ty, they are 45 l, crosspoint I am not sure of but a little over 2kHz is probably suitable.
35Hz port yes. My name is not Sebastian but Staffan, where did you got that from?.
L1 = 2.5mH (2mm d. wire)
L2 = 0.25mH (1mm d. wire)
L3 = 1mH (1mm d. wire)
C1= 4u7//u68 PP high quality
C2 =10u//2u2 PP high quality
C3 =33u NP//0.22uF PP high quality
R1 = 3R9 10W Mills
R3 = 15R 10W Cement
R1 = 3R9 10W Mills
R3 = 15R 10W Cement
According to data from Seas it seem ok up to at least 2500Hz.
H1471-08 CA22RNY
H1471-08 CA22RNY
Salas had some measurements I looked at and it seemed fine.
Look at the bottom of this page: http://www.diyaudio.com/forums/multi-way/144025-secret-building-good-2-way-10.html
In my opinion thats is a more complicated way of doing it, then to just upload the pictures to imageshack/photobucket or whatever and copy the link here. For an example, photobucket as i use resize the pictures for you and you can copy the link including the img tags ()or what they are called, directly from photobucket. Three simple steps, upload to photobucket, copy the link, post here
And it's a easier way to organize the photos in your post as well.
Thats what i think, but everybody prefers their own way of doing it!
/Sebastian
Hi Sebastion, what's easier isn't necessarily best
The disadvantage with image hosting sites is that the images don't always load properly, some people can't view them at all (for instance at work because they block image sharing sites), and lastly if the images become unavailable for any reason in the future the thread can become useless
That is why I said the preferred way to do it is to upload to diyaudio. It ensures the pictures are viewable by everyone, and remain available in the future.
back on topic. Starre nice work!!
Tony.
Hey, you said you will and you did make it. Nice progress. What is this Sebastian surreal call anyway?
Steve Harley & Cockney Rebel - Sebastian - YouTube
Hi Staffan,
I think tigeropolis (who is also from Sweeden) is called Sebastion (see the quote in my post above )
I think that's where schmutziger got it from. He probably looked at the flag and not the username and thought tigeropolis was you.
Tony.
Tony.
Yes no problemo, it was quite fun.
Something to mention about the building: I used Shellac for the inside of the cabinet and it worked great. Using it on the bare parts of the MDF baffle was ok but the surface got quite rough, but my intention is to use filler later to get the whole box smooth, then paint it.
- "Tired2way" speaker building.
