TINA spice simulation gives floating warnings
ok, I added R5=47 Ohm and now I have the following:
gain:
so why is this R5 is so critical?
Well, I just started reading about op amps...
I just found out that if I set the voltage back to 3,3V I get that weird gain curve again. And it stays the same no matter if there is R5 or not. But increasing VCC to 5V gets back things to normal...
That's because the supply voltage is too low for the required gain.
By the way, the LT1215 is not a good choice for your application, it looks to have a high noise figure.
Try using an NE5532 for your sims because once that works reliably you can then try alternate OPAMPS.
I would like to ask here not to open another topic... I am trying to simulate the PeeCeeBee V4H amplifier ( https://www.diyaudio.com/community/threads/peeceebee-v4h-gb.317151/ ) in the TinaTI program. Everything is OK, except I can't get a square signal response. The circuit is attached. Everything else is OK, except for a slightly higher THD compared to the amp specifications.
I would ask for help. Thanks.
