Boards would be nice to have. Is there a bill of material available anywhere? Are the other boards with this for the power supply? To sum it up:
Is there anything anywhere that links an NS10 Schematic, Bill of Material, PS boards for NS10 and Power Supply boards on the same page?
brutepuppy said:Boards would be nice to have. Is there a bill of material available anywhere? Are the other boards with this for the power supply? To sum it up:
Sounds like a nice builders manual!
Some of the fun of it, is searching through my immense Digikey and Mouser catalogs looking for parts.
I think once I have boards in hand, it's a bit easier to buy caps and whatnot knowing their spacing etc.
I am sure there will be new builders threads and bom's as people start to order parts for their NS-10's. - But if this road has been traveled already - please share!
I made a previous DigiKey BOM in .xls. I can email someone who is able to improve and post it.
Cheers
Cheers
JC Fardo said:I made a previous DigiKey BOM in .xls. I can email someone who is able to improve and post it.
Cheers
Jose, Can you PM me, I would like to review.
Improve it, probably NOT. I might be able to make it worse..Put all SMD parts in and whatnot!😀
NS10 Lineamp
Guys,
All parts can be found on DK, this preamp is an easy one. I would suggest you use the PSU and Tooleregs PCB’s as on the GB thread I pointed before.
The last schematic and board layout can also be found on the GB thread.
Guys,
Improve it, probably NOT. I might be able to make it worse..Put all SMD parts in and whatnot!😀![]()
mithomas, YGM
NS-10 power transformer voltage???
Does anyone know the voltage rating for the original power transformer on the NS-10?
Thanks a million!
Thanks a million!
Wiki Layout
is post413 the latest layout?
Could the Wiki link be changed to point to the current layout and not the previous PCB.
Re: NS-10 power transformer voltage???
Yes, it is 24V on the secondary winding.
nik_martinov said:Does anyone know the voltage rating for the original power transformer on the NS-10?
Thanks a million!
Re: Re: NS-10 power transformer voltage???
Happy New Year Steen and everyone!
Steen, do you want me to measure the one in the NS10 I bought from from you last summer?
Rolv-Karsten
Rolv-Karsten
Re: Re: Re: NS-10 power transformer voltage???
Happy new year R-K and everyone else🙂
My notes says 24V AC on the secondary but if you want to make absolutely sure, you are welcome to check the voltage. Thanks a lot. Even better would be a picture of the Threshold NS10 and the Threshold A400 of yours. I cant think of a cooler and more legendary set of amps😎 I am very happy that the NS10 has found a true Threshold loving home, driving its real mate the A400.
Rolv-Karsten
The pair is playing splendid, but I need some better speakers. The ESL63s are stored away for some time due to space restrictions! But the NS10/400A is a nice couple.The Fred and Ginger of amplifiers! 🙂
steenoe said:One more picture. This is the whole family.
The small board in the middle is the B1 buffer.
Is anyone making PCB's or a kit for a B1 psu board?
Steenoe:
Perhaps you know 🙂 Will 10mm L x 5.8mm diameter diodes fit on the CLC board? I found a suitable part at Mouser for the inductor, 580-19R473C but I'm not sure how well it will mount on the board, ideally some other mounting holes would be added... if I used this, I'm not sure whether or not the capacitor positions would be blocked... either way, the 1120-470K-RC part at Digikey fits like a glove. Anyways, all I need to know is diameter and pitch for the 2 CLC capacitors and diameter and pitch for the first cap on the shuntregs (C4)?
Thanks!
Steenoe:
Thanks!
I tried to measure on the populated boards, but it is a bit difficult to get a precise reading.
As far as I can judge, the diodes you mention should fit (barely) Not sure if the legs of those will pass through the holes, though.
The 47uH Murata inductors should fit pretty nicely. The datasheet says 10mm dia which is fine, but the Mouser-catalogue page says 12mm which is gonna be tight if you use the biggest lytic's possible for C1 and C101. I suppose the datasheet is correct. There are 2 sets of holes for the inductors, and the inner set is approx 6mm spacing.
Manu, could you post a boardlayout to scale? That would make it a lot easier to look for parts. Otherwise, I beleive that Tony has the precise Dia's and pin dist's.
Raw supply
The original layout has the following lead space alternatives for the inductor
7.2; 9.8; 16.0 and 19.1mm
The actual Gerber's could be a bit different and that could only be answered by Manu.
Cheers
Cheers
steenoe,
In post:
http://www.diyaudio.com/forums/showthread.php?postid=1632988#post1632988
You eliminated the RC network to power the B1 with the Toole regulator.
Did you eliminate the entire RC Network? R1,R2,R3,R4, C1,C2,C3 D1,D2 ?
Looks like you have 2 regulators. Actually two separate power supplies back to the transformer. Does this give better separation or better sound, compared to one regulator?
In post:
labjr said:steenoe,
In post:
You can only remove R1, C1, and C2. The rest of the parts works as a voltage divider to set the gate voltage at half the DC value of the supply. (R4 and D2 is just for power-on indication) I am not absolutely sure, if it is a good idea to remove C2, since it changes the time constant at powerup. I removed C1,C2 and R1 and kept C3, and it worked fine for me.
Yes, 2 seperate supplies is for getting maximum channel seperation. Since this is DIY, we can afford to go a bit overboard. It is not really needed though, the circuit is Class A and the crosstalk will be neglectible.
- Threshold NS10 Lineamp PCB
