http://worldnetdaily.com/news/article.asp?ARTICLE_ID=59991
You'll get no argument from me on that one. I have believed for awhile now that the sheer quantity of oil and gas that has been available (and will continue so) suggested abiotic synthesis. The fact that you can drill to almost any depth in the earth's crust (to the limits of technology, in fact) and still find oil should suggest something other than "fossil fuels".
John
For at least 10 years, I've known (well, about 6 months after P & F's announcement) that the right frequencies applied to cold fusion situations will produce the reaction/action one is after.
Read closely:
http://www.world-science.net/othernews/080206_molecule-sounds.htm
Who needs lasers to aid in chemical reactions....when like the monks....you can just hum a few bars?
Read closely:
If you read very carefully..you will find that this article validates the premise and statements made in classical, +2000 year old ...alchemy. All of it. 110%. Up to and including the monatomics, metals transmutation, etc, etc.
Go to the alchemy illuminated site, read all there..and then go interpret the physorg article with those eyes..and you will see it.
Plain as day. There you go.
http://www.philosophicalmercury.page.tl/Home.htm
http://www.physorg.com/news121622781.html
"Using this method, carbon nanotubes (CNTs) are formed in a bulk carbonaceous solid from thermal decomposition of melt-processable precursor compositions formulated from organometallic compounds or metal salts in the presence of an excess amount of selected highly aromatic compounds."
Alchemy, in it's more modern sense (but the oldest methods are still the most pure, in their own way) is all about temperature and pressure control of vapour deposition via/with aromatic compounds, as well as use of organometallic salts in said 'creations'. To create materials that are not 'common' or recognized as being common. At least not yet. Specifically, for human consumption and aiding of the body/mind bridge to the avenue of multi-dimensionality. The making of gold was more of a primitive adjunct of such work..with little to no real value. Once one understands the purpose of the Alchemical works, the gold (as an aim) becomes utterly meaningless.
What does this mean? It means you can get one hell of a lot further down the road than the best that current cutting edge science is doing.....by looking closely at alchemy. Apply that to the science in question on the physorg article..and there will be practically no limit to where you can go.
Then, everything I've ever said in any thread on this website, that seemed bizarre...suddenly begins to take concrete shape in your mind as a viable and workable thing. It's a total blast. Have fun!
Check out this Vogelzang Wood burning apparatus
5005555 Wood burning apparatus
http://www.pat2pdf.org
Look at the map at the bottom of this page http://www.bobdenver.com/
As mentioned earlier, the universe we commonly think of and exist primarily within...is apparently made up of 2-d stress fields that are oscillating in their respective ways,and the meeting point between them becomes a balanced force and resonance pair of vortex's one inner one outer, opposing directions. As similar to the recent discovery of what tornadoes are.
"As above, So below." There is a reason that such an utterance came into being.
Recently scientists discovered that light can be twisted like a corkscrew around its direction of travel. This unusual quantum feature allows photons to whirl around in a vortex, even when no external force is applied to the beam. Now researchers from the RIKEN Frontier Research System in Wako have shown that the same kind of vortices can be produced in beams of electrons ("Semiclassical Dynamics of Electron Wave Packet States with Phase Vortices"), promising novel applications.
"When a light or electron beam is twisted, waves at the central axis cancel each other out forming a dark core, like at the eye of a storm (Fig. 1),” says RIKEN scientist Franco Nori, also with the University of Michigan in the USA. His RIKEN collaborator Sergey Savel’ev, also at Loughborough University in the UK, adds: “As the photons or electrons spin around the axis, they carry orbital angular momentum that can rotate an electric dipole.”
To explain these properties, the researchers solved the Schrödinger equation of quantum mechanics for a twisting beam of electrons. This produced new dynamical equations that are highly analogous to those found for light. The similarities arise because the twisting angular momentum of the electrons interacts with their forward motion in the same way that intrinsic angular momentum (spin) interacts with the motion of photons, which is known as spin-orbit coupling.
The theory implies that vortices in electron beams have all the features of optical vortices. This reinforces the famous concept of wave-particle duality, which states that all particles have a wave associated with them. More importantly, it means that the useful applications of optical vortices could be replicated at much shorter wavelengths.
In practice, optical vortices can be made by passing a laser beam through a fork-shaped computer generated hologram. Electron-beam vortices could be produced in a similar fashion, using a thin crystal plate with a dislocation. Such vortices could power tiny nanomotors and nano-engines, or could be used in telecommunications by storing information in the optical vorticity, or the intensity of twisting. The vorticity is robust against perturbations, so this potential future technology could reduce the loss of information during optical communications.
Furthermore, electron vortices are predicted to cause a shift of the electron beam at right angles to an electric field. “The unique electron microscope developed by Akira Tonomura's group, also at RIKEN, could observe this unusual effect,” says Nori. “Such work would considerably expand the textbook analogy between matter and waves which Tonomura helped to establish in pioneering experiments."
http://www.nanowerk.com/news/newsid=4770.php
Are you getting this yet? So..tossing that thinking about, what does that mean for ...oh..pick something contentious...the Einstein aided 'Philadelphia Experiment'? Using high intensity (resonant molecular frequency) electromagnetic/electrostatic waves to render a large item 'invisible'? And the possible side effects? Hhmmmm.. maybe not so crazy after all..
“The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends upon the unreasonable man." --G. B. Shaw.
I've always said that, " the more difficult the problem is to solve, the more fundamental the mistake in the base information. Really stubborn problems usually require a through rethinking or a complete revamping of the basics."
"Problems cannot be solved by thinking within the framework in which the problems were created" --Albert Einstein.
"The study of history is a powerful antidote to contemporary arrogance. It is humbling to discover how many of our glib assumptions, which seem to us novel and plausible, have been tested before, not once but many times and in innumerable guises; and discovered to be, at great human cost, wholly false."--Paul Johnson
I always find it interesting that one has to be a member of DIY to see this forum area.
Once again, referring to my signature, with respects to '3D reality' being made up of the vortex (vortex in vortex out..in balance) 2D stress fields at their interaction/intersection point, and the resultant outer vortex being the one that predominates and creates the singular/linear/directional aspect of time..and thus linear 3-D reality.
Physicists at the Georgia Institute of Technology have made two important findings regarding gold on the nanoscale. They found that applying an electrical field on a surface-supported gold nanocluster changes its structure from a three-dimensional one to a planar flat structure. In another paper, they relate their discovery that gold in this size regime can be made magnetic through oxygenation of gold nanowires. They also found that up to a certain length, oxygenated gold nanowires behave as a conducting metal, but beyond that, they become insulators. This marks the first time on the nanoscale that such a metal-to-insulation transition has been found on the nanoscale. Both findings are important predictions that could some day be implemented as control parameters governing the chemical and physical material properties employed in nanotechnology.
The researchers focused their theoretical investigations on gold nanostructures because of the well known chemical inertness of gold in the bulk form, allowing one to maintain samples with minimal influence on the environment.
“However, we again find that small is different,” said Uzi Landman, Regents’ and Institute Professor, holder of the F.E. Callaway Chair, and director of the Center for Computational Materials Science, repeating a phrase that he coined and has used often for close to two decades. “On the nanoscale, even gold becomes a potent catalyst, exhibiting new and surprising, chemical, mechanical, electrical and magnetic behavior, which could not have been extrapolated or predicted on the basis of our knowledge about this substance in the bulk form. Some of these systems may find technological uses in nanocatalysis and as chemical and electrical sensors,” Landman added. ...
http://www.gatech.edu/newsroom/release.html?id=1738
Once again, this fully supports all aspects of the 'alchemy illuminated 'website, and also, the 'abiotic' method of oil production in the earth, the two being one and the same, in critical aspects. What this says, in general and the specific, is the stick and carrot of 'peak oil' is well known by the critical people involved, to an absolute lie, as the soviets have proven over and over again.
Abiotic Oil Production
If the idea of multi-dimensional existence is a bit too much for you, I suggest you look into it and begin 'getting thine monkey over it', as that's the next step for most of us who do not fear things in general.
When it comes to public and even investigative evidence of such topics, the persons involved in attempting to curtail such have this to say:
Two thousand years ago, a Roman Senator suggested that all slaves wear white armbands to better identify them.
"No," said a wiser Senator. "If they see how many of them there are, they may revolt."
In other words, if folks knew how much of this stuff was actually out there............ .. . . .
concerning my signature:
David Radius Hudson said that the monatomic forms of the platinum metals group, due to the US 15 second burn (compared to the soviet academy of sciences method of a 300 second burn in a neutral atmosphere to preserve the carbon arc rods) in spectral scanning via arc combustion....leads a false understanding that the entire atomic table can be found in 15 seconds or arc burn. Like the water in a pot burning away and then the pot heating and burning, Hudson said the 'known' atomic table of elements needs be burned away before the monatomics show up.
He also stated that due to this 15 second burn test, the monatomics would be falsely shown or come up as a false reading of things like silica, iron, aluminum, etc. Basically, they tend to show up as 'salts' of metals. They are recognized many times as salts or similar. The monatomics are apparently oxidized version of the PMG group, that come from transmutation of the PMG done in the deep bowels of the earth, and then seen as salts. Oddly, the same claims of the abiotic method of oil production, with regards to the creation of the Alchemical mercuries..or dissolving 'solvents' for the purposes of transmutation.
Under that bit of thinking, cast your bean on this, which is likely the 50th or more incident of similar nature that I have taken note of:
" RF imitates platinum catalyst
On June 16, 2007, Charles Kilmer wrote (http://tech.groups.yahoo.com/group/kanzius_effect/message/29) to the kanzius effect discussion list:
I wrote a blog on this topic. Some of the links go back to this discussion group.
http://nick2.wordpress.com/2007/06/01/saltwater-into-fire/
I have an updated post Here: http://nick2.wordpress.com/2007/09/14/kanzius-and-penn-state-chemist-rostum-roy/
Read through the blog carefully.
What you should see is the secret sauce to the Kanzius effect. Its contained in one of Kanzius patents and in an expired eu patent.
What's happening is that the RF is imitating the radio frequency of some catalyst for water separations. My guess is that the catalyst frequency that's being imitated is platinum since that's the big expensive catalyst in hydrogen fuel cells. What's happening is that the salt water is fooled into believing there's a platinum catalyst in the water.
The other thing that's happening is that the Na is getting really hot really fast. Na --like any metal in a microwave is a heatsink. The water is first destablized by the RF and then its broken apart by the superheated Na.
Now consider if they could eliminate platinum from fuel cells altogether while using salt water as a storage and fuel for hydrogen -- suddenly hydrogen fuel cell cars would be dramatically cheaper.
To see what I mean consider this article on hydrogen fuel cells
http://www.lanl.gov/news/index.php/fuseaction/home.story/story_id/1673
Background paper: Fuel cells at Los Alamos"
Hudson said he did much work with General Electric, in their fuel cell work, regarding them using his monatomics as fuel cell substitutes for the PMG metals...and when the GE researchers put his monatomic 'salt like' materials in their fuel cells, it performed as good as or better than the platinum metals they were replacing and when the scientists took the fuel cells apart after the experiments were done...they found PMG metals in the cells...that somehow came out of seemingly....nowhere. The monatomics had begun to convert back to their 'metallic' form.
This is essentially a modern chemical/electrical version of 6000 year or older...alchemy. Alchemy is all about the creation of solvents, salts from metals and catalytic states of said substances used in standard chemical cooking and pressuring... to... transmutate.
It is interesting to note that the claims of perfect health from the monatomics.. severely retarded aging and corrected DNA, curing of all disease, etc.. are found in the work of Jim V. Humble, a metallurgist and prospector who found a way to include the same said salt (Kanzius's salt water solution!!!) solution used in the salt water hydrogen resonance/burning experiments..to create a near 100% cure rate for malaria...typhoid, and many other conditions..by simply drinking a cupful of properly prepared oxygenated/salted water. Interesting thing is that Kanzius is attempting to cure cancer, by the way. Odd how they end up at the same spot? I think not.
Fancy that.
The Synchronicity and truths are there if you've got the balls to go and look at them.
Hmm..RF for the properly prepared 'cold fusion? All kinds of directions can be gone in here. All appear to work quite wonderfully, if you bother to find out exactly what the function and the mechanism actually are. A million different workable directions are indicated here, if you can be bothered to go and look at them.
Fancy that.
Banyugeni, according to Khoiruddin, currently has four different product variants — hydro-kerosene, hydro-diesel, hydro-premium and hydro-avtur. He said these were equivalent to their fossil-fuel counterparts kerosene, diesel, gasoline and airplane fuel.
“In the future, we will also develop other product variants that are superior to existing variants,” Khoiruddin said.
He said the newly invented fuel had been tested by PT CoreLab Indonesia, an independent international laboratory, and had been subsequently declared to meet the standards of the Directorate General of Oil and Gas at the Energy and Mineral Resources Ministry.
The test result, he said, was convincing. Hydro-premium, for example, proved to be non-corrosive, non-residual and to show low-emission rates.
The hydro-avtur is similarly non-corrosive, low in emission rates and has a low freezing temperature of minus 45 degrees Celcius.
“The test on aero-modeling crafts shows that hydro-fuel can be categorized as jet fuel,” said Purwanto, adding that this particular variant ran cool with an initial boiling point of 164 degrees Celcius.
Similar results were shown from tests on hydro-diesel and hydro-kerosene variants, Khoiruddin said.
An experiment at the Surakarta aviation education and training institute Tutuko using an ultra-light Jora aircraft with a Rotax 582 engine on Feb. 11, 2008, according to Khoiruddin, confirmed Banyugeni’s variant of hydro-avtur could satisfactorily start the craft’s engine and achieve maximum take-off power.
Purwanto said hydro-fuel was produced using so-called “mechano-thermal-electro-chemical” technology involving four processes: mechanical, thermal, electrical and chemical, all using water as the raw material.
“Water is basically flame. It comprises explosive hydrogen and flammable oxygen,” said Purwanto.
The process of turning the water into hydro-fuel, he said, was basically keeping the two atoms in the water in such a position where the water could revert to its constituent elements, hydrogen and oxygen.
http://www.planetmole.org/indonesian-news/hydro-fuel-inventions-yogyakarta-central-java.html
The basic premise behind Brown's gas can certainly be manipulated, can't it?
Kinda reminds me of alchemy. From fine powders of PMG elements to monatomics through maximum levels of PH mood swings. Ionic 'resonant' slamming.
This is more of the same, but like Brown's gas, with with an electrical assist. And then pop it back down..with the spark..and 'combustion'. heh.
Then you add resonance. As you would for cold fusion. Find the resonant freq....and slam it.
"mechano-thermal-electro-chemical" Folks.
That's abiotic oil production in the earth..that's it's conversion of PMG to monatomic state.........and that's the exact methods of how the alchemists get it back out again.
There is no gas shortage.
There is unlimited supply.
There is no precious metal shortage.
Like the oil, it is everywhere.
1) What's happening is that the RF is imitating the radio frequency of some catalyst for water separations. My guess is that the catalyst frequency that's being imitated is platinum since that's the big expensive catalyst in hydrogen fuel cells. What's happening is that the salt water is fooled into believing there's a platinum catalyst in the water.
2) Researcher Nike Triwahyuningsih said for further processing of hydro-fuel, the water needed to be purified. Once processed, Nike said, a liter of pure water could produce about the same volume either of hydro-premium, hydro-kerosene or hydro-diesel, according to the desired results. “We used seawater for the research, but basically any water including liquid waste can be processed into hydro-fuel,” said Nike.
I guess 1) and 2) are using different physics?
An old(er) technology becomes viable, due a tiny bit of a newer design spec..ie,a bit of thought put into it.
Never forget to go back and rehash the old, or established way of thinking. Never assume the old way of doing something is always the best, or most correct. A tough trick for some folk.
A 40% efficiency increase in thermoelectrics.
This means for both Peltier and Seebeck devices:http://en.wikipedia.org/wiki/Thermoelectric_effect
http://technology.newscientist.com/...ted-material-turns-waste-heat-into-power.html
Scott: You may be right. I went and looked a bit more closely at the two, just after I posted said article links. I realized that they may not be quite the same thing. A bit of a 'jump to conclusions' on my part. Due to the nature of the posts I'm making, in general, and how contentious they are, I'm stuck with a really high bar and standard.
As for the oscillating 2-d stress fields at their interactive and intersecting points creating a 3-d reality vector, there is a book that deals with the entire subject in an interesting fashion. It's by Dr. Raj Baldev. It's bit a difficult to get in North America. That may have changed by now, but they had to be ordered out of India, and one had to wait months to get it.
http://www.internationalreporter.com/news/read.php?id=287
isbn:81-88039-21-7
isbn:81-88039-21-7
More Nanomaterails and alchemy. Or, exactly what David Radius Hudson said about the monatomics-which is alchemical in nature.
Still think all those stores about the Ark and the sumerians, egyptians, etc..are all baloney?
Solomon's Temple and the Ark of the Covenant was all about ancient salt beds being turned back into (washed and separated) monatomic materials or back into the base metals, as an energy, power, enlightenment, and financial (precious metals) source.
You are an electrochemical creature. Alchemy is about electro-chemical transmutational processes.
It takes a considerable amount of time for the evidence to mount in your mind, as the variety of evidence in the various places it may found..are scattered, and it requires some serious investigation over considerable time. This work will finally show itself to a be a very simple and cohesive whole.
There is enough in this thread to get that job done.
Think again. Or, conversely...think for the first time.
Nanomaterial turns radiation directly into electricity
http://technology.newscientist.com/...urns-radiation-directly-into-electricity.html
hhhmmmm....
Increased media reports will first likely lead to disclosures of secret antigravity technologies that have been withheld for over 50 years, as a prelude to official disclsoure of extraterresrial life. The source's reference to suicides is probably related to those who will learn that much of what they have learned and believed over a lifetime was a lie. The 1961 Brookings Report referred to scientists as being most vulnerable to the disclosure of extraterrestrial life since it will make redundant many of the cherished scientific theories and models held by this community.
http://www.ufodigest.com/news/0208/unmeeting.html
- Member Areas
- The Lounge
- Threadjacking
