Thorsten's Valve Output Stage with TDA1541DAC
What I can see from the simulation a few pages before, that filter has a big big peak around 20kHz.
Is that necessary only for the TDA1541 in non os ?
If I built a brickwall filter for a BB non os DAC with -60dB at 44,1kHz, should the cutoff point be at 20kHz or 22 kHz ?
Should it have a flat amplitude response or a peak around 20kHz ?
oshifis said:
Hi Sándor,
I recommend the following:
1.) Disconnect the DAC from the tubes. If the hum is still there, it is in the tube stage. If not, there is a ground loop with the DAC.
2.) One end of the filament should be grounded.
3.) Inter-stage shielded wire is not always a good idea. Try twisted wire from UTP Ethernet cable.
4.) I would not put the AC socket so dangerously close to the analog stage.
5.) A good test is to disconnect the AC power from the three transformers one-by-one with a temporary switch (with caution, shock hazard!) for a few seconds, and see if the hum ceases.
1) Disconnecting the DAC does not help. The hum is generated by the output stage.
2) I have tied the filament to ground both directly at one end, and with two 120 ohm resistors and center tap. No change. During the short time immediatly after having disconnected the E88CC filament, the hum is still there. Then it strongly increases and short after the signal (of course) vanishes.
3) I use a shielded wire to connect the anodes, in the center of the board, to the output connectors at the left and right ends of the board. I have not tried with a twisted pair. Do you think it is a worthy mod?
4) During tests AC power was directly connected near that blue transformer (please see picture)
5) In the analog stage there is only one transformer. Those devices below the output stage board, that look like transformers, are the two anode chokes.
Andypairo said:
do you have access to a scope?
If so give a look at the hum waveform and see if it is related to the PSU ripple.
Please look at the attached image taken from a Velleman PCS500 DSO (H=10mS/div V=5mV/div). The level of the signal is 6.25mV RMS and it is clearly related to the 50Hz power line.
Andypairo said:
The P2P assembly is way too big imho, and since we are dealing with mV levels at the tube's grids the AC inlet seems too close.
Try moving the I/V pcb outside the case.
I have pulled the output stage board off of the box. No change.
Andypairo said:
If you only connect a single channel output does the hum stop?
No
carawu said:
Try moving the choke and trannies.
No change
Do you think that I should completely rearrange the layout of the board?
Best regards.
Paul
Sandor said:
I have also substituted the EZ90 with two solid state rectifier and changed the two 220uF capacitors with fresh ones.
No change.
Paul
How is the grounding done? Starschema is the most safe (regarding hum) in my experience.
Is tda1541 ground connected to I/V ground? Did you disconnect ground this when disconnecting I/V from DAC and still got hum?
Do you have a metal tube/shield to shield the ecc82 (as it is close to the chokes)?
HUM PROBLEM SOLVED!!!
Carsten
I have rotated the two anode chokes (right channel 90 degrees and left channel about 45 degrees) and the hum is almost disappeared.
What is the cause of this strange behaviour?
Is there a way to shield the chokes (or supply transformer and choke) so that the hum level is independent from the orientation of the chokes?
Thanks to you all.
Paul
Re: HUM PROBLEM SOLVED!!!
Fine!
Magnetism.
Maybe shielding with Mu-metal.
Carsten
