This is either very wrong or I have still not understood diffraction from baffle edge
Two LeCleach horns won't meet up when back to back, an attempt to force early termination means a reflection. Not that this is the worst option, it's more that they're just so clean to begin with.
The downside is that the sliding parameter that allows them to have such good specs is the directivity. This directivity goes from one extreme to the other.
Thanks, I think I understand, but I'm not sure. Regards a dipole, the short time delta of the diffractions at an abrupt baffle edge causes the relatively narrow, deep null, and by comparison the null is spread wider around the curve of the torus baffle due to the longer time delta, the peaks are likewise spread and thus diminished?
I'm not clear on what you are saying. When a circular baffle is used in a dipole there will be on axis ripples from the edge diffraction, which will move lower as the radius of the baffle gets larger, going away for an infinite baffle. With a torus there won't be any significant diffraction (a small amount at LFs) so there won't be any axial aberrations. The directivity will change however - from an infinite baffle.
I still don't understand why there appears to be no on axis interference nulls with the torus, are you saying it's because there's no significant diffraction?
It does appear that's exactly what he's saying. Possibly for the same reason that doing a wide, gentle radius on a typical baffled speaker would also reduce on-axis interference.
That is correct.
I didn't understand why the effects of the diffraction was dismissed so readily by Charlie Laub. It made me wonder if I'd missed some other explanation or fundamentally misunderstood the meaning and nature of diffraction.
I have a number of problems with that post on a technical level.
I read those posts and had a problem with them as well. I didn't like the tone of the thread so I avoided it.
