lemme see, i believe that "square head" is not exactly a "term of endearment" up there. It's sui generis of politicians down here.
Exactly. I think Peckerwood was probably referring to slot rather than flathead. From the days when the slot was cut rather than drop forged. And the only one that works with a dime in a pinch.
Far and away the #1 screw head here in Canada.
A slotted screw is driven with a 'standard' screwdriver - nit picking but that is the true name.
Probably WAY more Philips drive screws driven in Canada, as they make drywall screws with this type of drive. There is probably more drywall being screwed on than fences and decks (and other uses for Robbie drive screws) being built.
Yes John, we were referring to the post by Peckerwood where we think he was referring to the slot rather than the flathead head.
Yes, thank you for that. A perfect reason for a Phillips head. I had forgotten about drywall screws.
Lucky Louie might have been the best TV show ever.
The Hate/Annoy list is far too long for me to write here.........One that stands out, perhaps Sad, and not hate........hate is so extreme.
I feel so sad when my teenage son tells me "Turn that music down its too loud!!" Then he "jams out" to an episode of "Glee" on the computer.
_____________________________________________________Rick...........
I hate it when our choir director asks the sopranos to sing more loudly -- they don't understand that he's only kidding.
The impression of the Kenny G haired naked roller was all the money in the awesome possum vid.🙂
Banks, bankers, sons of bankers, and Larry Kudlow.
Not Paul Krugman? Last time he wrote a serious peer review article was in the early 1990s.
Kudlow bothers even me, when he's on CNBC I turn it off...when he's on WABC I switch to WQXR.
Krugman, right or wrong, realist or psycho, isn't owned by Wall St.
Now, back to the original topic: Blankfein, Dimon, Bernanke, Geithner, Trichet, all of CNBC, and the wives of bankers. 😎
I hate slotted and standard screws. I thought they were called flathead screws but I stand corrected. I have injured myself many times messing with them because the screwdriver can slip out of the slot so easily. They are not so bad if they are loose but when you have to put a lot of muscle into them they are dangerous as well as a pain in the butt.
Another thing I hate is the todays dictionaries. They change their definitions based on the way people improperly use words. They didn't use to do that. I remember it taking a couple of hundred years before they put "aint" in the dictionary. We were expected to go by the dictionary. Now it is the other way around. People abuse the language and they modify the dictionary to suit them.
If you don't believe me look up some words that you already know the definition of and I bet you will find a lot that have changed since last time you checked. The definition of racist has changed at least 20 times in the last 30 years. It used to be you had to do something to be a racist but mow all you have to do is recognize that there is a difference between races.
One example. Nauseous always has been a word but never meant the same thing as nauseated. Nauseated was the way you felt and nauseous was whatever caused you to feel that way (like bad food or whatever). People misused it and then the dictionaries added the new definition and it is usually the first one shown. That is ********. How are we supposed to use the language correctly when the dictionary keeps changing?
might have been
You should see my *******. What if you needed to identify me ?
Priceless.
I hate the united states postal services; after more then a month the have still not delivered my t-shirts that I ordered at DIY audio :-(
A-bart(h)je,
give it time, my black LS shirt didn't check in yet either, Mr Norton said i was the first one to order.
I hate being battery powered on an island and discovering that its the CQ worldwide vhf DX contest and only a dipole. But that is my fault, and easy to fix.
It could be worse. What if you were stranded on that island during the worldwide VHF DX contest with nothing but an 11 meter radio during the peak of the 11 year cycle?
I would put in a new crystal and go up to 10 meters.
Somewhere around here I have a transmitter from the era before 11 meters was given away.
I hate when you diet and excercise and your weight doesn't well track your effort. Tuesday I had a big greasy burger with cheese fries for lunch and pizza for dinner, and missed my workout. Got on the scale Weds morning... lost weight. Wednesday I had very light soup 'n salad, some fruit and almonds, and generally ate very healthy, worked out... slight increase this morning.
'taint fair!
'taint fair!
- Member Areas
- The Lounge
- Things We Hate
