This one models pretty well in 10 liters with your woofer. EDIT: I didn't look at the depth when I posted this originally. It's too deep for your design. I'll look at another and post in few minutes.
If you only use one, the Xmax of the passive is exceeded at full power below about 55 Hz. Depending on how you intend to use the speaker this may not matter to you (typical listening volume and subwoofer use). If you want maximum output and low frequency performance, two of them would be better with about 30 grams of added mass per passive radiator.
You could start with one passive radiator to do basic tests and add the second later if you like how things are working together. The sound won't be significantly different between 1 and 2 passive radiators except at high levels with bass around the tuning frequency (about 40 Hz).
Dayton Audio DS175-PR 6-1/2" Designer Series Passive Radiator
The problem with using smaller passive radiators is that compared to the woofer you typically need around 2x the volume displacement for the passive. You'd probably need 4 or so smaller radiators to get that.
