I wouldn’t eat the darker ones by the water but we tried a couple of the inland green ones in the smoker when I lived on my boat in Boca Grande FL (ca. 1990) they were actually quite tasty from what recall. They probably carry some nice diseases so take care skinning them out.
In case anyone’s interested, popped’em in the head with a pellet rifle.....makes it quite simple and doesn’t break any laws.
It is 13F (-10C) here, really gotta get the new furnace up and running. But two 1,500 watt electric heaters keep my house at 65F.
So far it has taken just under 100' of new plumbing and more than 30 elbows. Doesn't quite mount like anything before. I did find the air seperator as shown on the installation instructions. Not a real common part, meaning even McMaster Carr doesn't carry one! Also had to add a back flow preventer and pressure monitor three way fill valve.
I have managed to get the natural gas line in and pass a pressure test. Also have completely plumbed in the domestic hot water circuit and the new exhaust pipes. Just under half way through with the heating circuit.
I now understand why plumbers charge more than the furnace cost to install it. So far furnace was a bit more than $2K and the plumbing bits above half of that.
Good news is I found a penetrating oil that allowed me to disassemble the well rusted old heater. Actually looks like it can be repaired as a nice back-up.
Once the heat is back I will clean up my almost completely clogged cold water pipes. Very high mineral content here.
American basements are cluttered with mad max heating stuff for water and air. European combined heating/water boiler of 40 kW are the size of carry on luggage and one man portable. One of the things I really didn't understand when I lived in D.C.
A bit of a price difference. The usual 80 gallon tank water heater is under $700.00. Same price for a cheap hot air furnace that will allow for the same vents to do air conditioning. Real estate is cheap also.
My high efficiency furnace is the size of a suitcase, weighs 80 pounds and cost about $3,000.00 with all the additional parts. Will pay for itself in lower utility costs in 3 years.
Furnace?? Or 'boiler' (water heater)?
I have hot-air furnace. Historically these were large. Modern ones are fairly small. The limit is that air is thin, you must move a lot to transfer heat, and the peak temperature is now limited for best efficiency. So my house needs a 10"x6" fan. Universal application needs several inches all around so I can bring in the cold air any way I want. The fan blows over the fire pipes. I have 2 flames in a space which could fit 6 flames, true; there's not a strong reason to re-dimension the furnace (and it is convenient to have no or small steps in size). While outside the furnace proper, the "biggest" thing is the air filter, which is also the lowest air-velocity part of the air path.
I won't argue the wall and room and comfort factors of air versus water. The BIG old water systems held heat; this is true but less-so for modern lightweight systems. Hot air ducts have to be designed-in, especially multi-story houses, water pipes can be snuck-in anywhere (steam is an intermediate fit).
You want "big": outdoor boiler. Somewhat popular here. A BIG fire-box takes a whole day's worth of wood. Insulated pipes run the heat into the house. Fairly expensive but can burn long lengths of cheap wood. Probably something similar in Europe's north forest.
Around here coal was often used as the fuel source to provide domestic heat. So air, forced air and water or hydronic heaters were all called furnaces. My maternal grandparents' house was hot air without any fans that was originally coal but had been converted to natural gas.
The unit I now have provides both domestic hot water and a separate loop for heating water. Somewhat of a pain as the closed loop heating water requires a separate fill, expansion and overflow parts. My hydronic heating loop uses all potable water pipes and parts as originally the high efficiency tank type water heater did not separate the two types of water.
A boiler around here is a steam unit that vents steam at the end of the line, very old word usage. A closed loop system would be a problem if the water actually boiled!
I did have to get a refill on my acetylene torch tank! It is a 40 cubic foot tank I got from my father and last exchanged it for a refilled one more than 30 years ago! I am spoiled by that type of plumbing torch, hotter, faster and cheaper than the much more common propane/MAPP gas ones.
Also was quite handy to have the pressure gauge to test the gas line! I even have an electronic gas leak detector! Yes I have way too many tools. But my standard has always been you should be spending more on the materials than the tools. This project alone has passed that test.
For audio it means spend more on music than the sound system. (Humor if you understand I do install multi-million dollar sound systems!)
Tonight's forecast: Dark
Remaining dark throughout the evening, changing to widely scattered light periods in the early morning hours.
(Thanks GC, I hope I did you proud)
The Hippy Dippy weatherman, with the Hippy Dippy weather, man.
It was like -27C here the other morning, wind chill in the -40s...I don't generally mind cold weather, but even for me that's stay inside stuff right there.
Mike
Those of us in the cold northern climes could, I suppose, fly south for a warm weather vacation. It is 69F today in Antarctica.
It’s 62F here right now, so warmer in Antarctica than FL at the same moment in time.....go figure!
Some-one/thing beat you to it.I suppose, fly south for a warm weather vacation.
6 degrees Celsius (about 43 Fahrenheit) here in the vicinity of Vancouver.It’s 62F here right now, so warmer in Antarctica than FL at the same moment in time.....go figure!
But: the current temperature in Antarctica appears to be (-39 Celsius), which happens to be almost the same in Fahrenheit (-38 F).
Screenshot from TimeAndDate.com attached.
-Gnobuddy
I am down is sunny Georgia U.S.A. where it's a nice 39 f .
But I have a real reason to hate real cold weather. My darn
car has a short that only acts up when it's below 5F and drains
the battery. After it warms up a few degrees I can charge the
battery and everything will be fine for another year or two .
I got to test my new furnace. Weather report says night time temperature 13F, house stayed exactly at the thermostat temperatures. 75F in the bathroom and 68F in the bedroom, the rest at 65F.
I was wondering how the heat really would work. Attached is the plumbing suggested routing. Note the output of the furnace hot water and the input is basically short looped. The pumps draw from that loop. The thing to note is the furnace (Boiler for some) has an internal circulation pump. It also has an over pressure valve set for 30 lbs. That would be equal to about 70' of water height. The pump might be able to circulate it due to the pressure pull of the return, but with the pump off I would expect the valve to vent. So the short loop makes sense for that. Except the pressure from higher radiators is not effectively isolated!
Cold water enters the heat draw pipe! I do have to insert a pressure regulator on that line as I prefer to run my domestic water a bit higher than the 12 PSI suggested for the heating loops.
I was wondering if the heat transfer would work with the short return loop. I was thinking a valve might be needed to restrict the return flow and allow the zone circulating pumps more hot water. So the test today was of great interest. Seems to work!
It did take fourteen new valves and about 100' of new pipe, no section longer than 4'. Or about 4 full days of my plumbing. One drip I need to get to if it doesn't seal by itself from the normal minerals in the water. (About 2 liters per day.)
> short return loop
It does look wrong. Certainly if I mock it up in electric symbols, it looks like a dead short.
The nipple at the heater/manifolds U may need a minimum Aspect Ratio to control cross-mixing. However with forced flow, even 4:1 may be ample. Allowing for fitting depth, and room for wrench/disconnect, you probably can't make a cross too short to work.
It's not a "dead short" because the Loads all have their own pumps. If the loads are not pumping, you want the boiler pump output to come right back so the boiler will cut-out on hi-temp. I don't see a simple electrical equivalent because we have two types of "energy", thermal and pump.
Yah I thought that was a bit much........Tubesguy must get his weather from the Al Gore network!
Well I didn't say the South Pole. The continent is kind of big. These high temps were on the Antarctic Peninsula.
- Member Areas
- The Lounge
- The Weather
