Cobra 2
That is heavy, 200lbs, The first amp I built was only 95lbs, I thought that was heavy! There is a 100watt monoblock which only uses 2 EL34's in the book by E. Rodenhuis called Valves for Audio Frequency Amplifiers printed by Audio Amateur Press. It also gives you the wiring diagrams for the power transformers chokes and output transformers also all the measurements. I have the book.Should make a good powerful amp. Regards.
Weight...make good amps / iron really expensive to ship...to where I'm living. Unless someone can tow them trafos behind a freightship...
The good thing; they are (almost) theft-proof.
BTW, I have decided to make a long story shorter, and bought a restored & updated Dynaco ST70 here:
http://cls.audiogon.com/cgi-bin/cls.pl?ampstube&1173822896
If I get the taste of it...I will jump into over my head again.
Arne K
Arne K
