So do II sometimes feel something strange after a bottle or so.
Then I shut down my workshop and re-join the world until the effect wears off😉
For some additional info on "breadboarding" you may search through these sites
www.audio-consulting.ch
Wilfried
Wilfried
First Live Experiment......
"Probably next sunday, I will get the chance to place springs under a mates bass rig and some pa cabs at a pub beergarden live show (rock/blues) and see what results we get."
That was yesterday, and we tried springs under his bass rig - 2 x very heavy cabs each containing 1x 12" & 1x 10" driven biamped by a Trace-Elliot amplifier (rated 500W rms total).
We placed the springs under the bottom cabinet, and the amplifier on top the upper cabinet.
The bass coupling into the stage was substantially altered, and the bass sound also.
The bass rig ran only the last 45 minute set arranged this way, and the concensus from the bass player and my companions in the audience was very much affirmative.
With altered bass rig eq, the result was really smooth, clean and nice bass, but with more attack, dynamics, clarity and fidelity.
This band is rock/blues 3 piece, all players are world class with 30 years experience, and they can really crank it up when they want to.
The pa was used only for vocals, elsewise stage sound provided the music.
From 15 m back, the soles of my shoes were buzzing on carpeted cement floor very nicely, and the bass had a 'rightness' that I have not heard before, and this enabled the drums and bass to 'sit' very nicely and naturally together.
Now if only I could get the guitar to turn down a bit.......🙄
This is the initial experiment, and one night during the next week or so we will make better speaker cables, attack the cabinets and fit better wire and add some compensating RC networks, and then we should be really cooking.
SPRINGLOAD
Howdy Eric,
Have you considered springloading,say,the front of the cab with a pair of equidistant springs and using a decent (for the weight) spike at the rear?
It's just a thought...in that way the speaker,which puts out a lot of forward moving energy,would see a mechanical diode to ground whereas the rest of the cabs' bottom would be isolated from the stage floor?
May be worth the experiment?
Cheers,😉
Howdy Eric,
Cheers,😉
Not Yet......
Ummm, no I have not tried that yet.
When we get together one evening, there are a bunch of further little experiments to try, and a solid mount under the back of the cabinet may be one of them, but so far fully isolated by springs is working dandy.
How does a cone act as a mechanical diode ? - I have always been a little funny about this mechanical diode theory.
Eric.
Eric.
MECHANICAL DIODES
For what it's worth:
SEARCH RESULTS
It is an engineering principal mostly used in building construction.
Basically a mechanical diode can be a spike or a conical element that acts as an electrical diode conducting (draining) energy one way and blocking in the other.
It works best when an uneven number is used ( one is usually best).
The pointy part faces downwards and drains energy away from whatever is resting on top and at the same time preventing energy to flow back up.
Due to to conical shape of its' top energy is dispersed there and has a hard time finding a point of entrance.
(much greater surface area)
By careful placement it can be quite effective and if you had,say,a set of three cones it can be quite an experience if you turn them upside down,move them around under the gear and so on.
It all makes an audible difference.
For use under speakers I find these very effective when the cone (or spike) facing downwards is put at the heaviest point.
Often this is close to where to magnet of the woofer is.
One can than draw an imaginary triangle and find the best spot to maintain equilibrium and the springs or spikes can than be put there for stability and further drainage.
On a stage this can be tricky since often cardboard floors are used that can well put out more energy than the woofer cabs,so some experimenting may be useful.
In your case the fixing of the heavy cabinet to its' underlying surface should give tighter bass and less return from the stage to the woofer cone.
A woofer launches its' throw forwards and the less it is disturbed in this motional plane the cleaner it will sound given a solid reference to ground.
So much for the theory.
Cheers,😉
SEARCH RESULTS
Cheers,😉
Re: Not Yet......
Hi, Eric,
The term "mechanical diode" seems to come up
most when talking about torque converters for
transmissions. It's supposed to prevent some
piece of rotating machinery from spinning back
the other way.
The spike is not really a "mechanical diode"
at all. Rather, it's a coupler.
Check out:
http://www.soundstage.com/maxdb/maxdb.htm
Erik
mrfeedback said:How does a cone act as a mechanical diode ? - I have always been a little funny about this mechanical diode theory.
Eric.
Hi, Eric,
the other way.
Check out:
Erik
ERIC>ERIK>FRANK
Sorry to say so but that article conveniently ommits a number of physical principles where it seems to suit them best.
One always has to have a mass load of the supported device in proportion to vibration.
Be that airborne or structure born.
Isn't it obvious that when you put a lightweight object loosely on a set of cones it is not going to do any good?
Of course it is going to bounce and tremble around singing to its' own resonant frequency.
A bit too simplistic a view IMHO.
Cheers,😉
Cheers,😉
Springs Are Not Directional......
"Using footers under the component still changes the sound you hear, not because the footer decouples better or is a more effective mechanical diode, but because you prefer the resonant signature of that footer to the stock feet."
Erik, thanks for your link, and that is my understanding already, entirely.
Frank, I have read and understood your points too.
I do not believe the diode principal attributed to cones, but I do well agree that the surface area of the cone contacting the cabinet is of great importance, and explained in the link given in the previous post.
In light of this, then a sonic difference is to be well expected according to the directions and placements of the cones, ands in accord with my previous experimentation.
"In your case the fixing of the heavy cabinet to its' underlying surface should give tighter bass and less return from the stage to the woofer cone."
The springs are providing near perfect isolation - the stage buzzing was due to acoustic coupling, and not mechanical coupling.
The cabinets used are VERY heavy, carpet covered and reasonably inert, and the overall sound was different, and to several peoples ears, much improved.
The comment from the bass player was that the sound was different to what he was used to, that he needed more playing time to get more familiar with it, and that his rig was more responsive, articulate and expressive, and that so far he LIKES it.
Anyway, the result of this experiment is very much encouraging, and in line with previous experimentation with domestic cabinets.
I still cannot believe that no one has bothered to try springs yet, despite my suggestions and results.
Is everybody still mesmerised by rort, folklore and convention ?.
Eric, The Trendsetter.
PUDDING.
Eric,
As much as I would like to try it out my speakers just don't lend themselves to that kind of experiment at all.
Yeah...surprises me too.Seems we have more listeners than do-ers.
In fact,I think where your idea appeals the most to me is when applied under a CDP and/or a DAC.
Since most of these aren't moving about by themselves a couple of low Q springs would be beneficial,I reckon.
Perhaps a felt srip in between the chassis and the springs?
And...I would still only use three of them.
Any guinea pigs?
Grand Master Alu Peter Daniel perhaps?😀
Cheers,😉
Eric,
Any guinea pigs?
Cheers,😉
It Is Not That Difficult.....
I've tried three under my CD-94 and it did make a nice difference.
I also have three under my tube reciever and they make a nice difference there too.
Peter........? 😉
Eric.
Peter........? 😉
Eric.
Re: It Is Not That Difficult.....
Nylon monofilament works well too, especially if you can attach it from the top with 4. I think it works similar to rollerblocks as the motion would be about the same. If the filaments are a bit buzzy, clamp lead fishing weights onto them to change the resonance/damp it. If you have the equiptment positioned only a couple of mm from the shelf below, it looks like it's resting on it, so it doesnt look to strange or tweaky, because you can't see the monofilament.
If your rack is suitable, I've had success with hanging equiptment from tension springs attached to the shelf above.mrfeedback said:I've tried three under my CD-94 and it did make a nice difference.
Peter........? 😉
Eric.
Gone Fishing.......
Nah, not suitable in this case, at least not for speaker cabinets.
Years ago (20+) I mounted the edge of a board against the chimney brickwork, and ran two threads of strong fishing line (monofilament) from the brickwork down to to the outer edge of the board (at about 60 degrees) and placed my turntable on this arrangement.
As I remember this gave absoloutely no acoustic feedback, and you could jump all you liked on the floorboards without disturbing the turntable in the slightest, and it did not look look strange or tweaky in the least. 😀
Eric.
Eric.
RE:Gone Fishing.......
Anything in the monofilaments?😉
Just a little Q:
When you use springs,are these conical or straight coils?
I think you know what I'm getting at🙄
Cheers,😉
Just a little Q:
Cheers,😉
Just Put Cones Top Or Bottom.....
Hi Frank,
The coil springs are automotive valve springs - straight wound and ground flat and square both ends.
Using some kind of conical wound spring would minimise the contact area, and this may be a benefit.
So far the flat ended ones work fine for me, and give good lateral stability AND you can get them for FREE from any motor mechanic.
Eric.
Hi Frank,
Eric.
ROCK&ROLL SPRINGS
Hi Eric,
I thought as much.
Rocker valve springs they're called, I think.
What I had in mind is the same strength (Q) spring but conically shaped so you can put them wide side facing down for increased lateral stabilty.
I have no idea if such a model is used in automobiles though.
Maybe you came across any?
The idea apeals to me since this is what we used in a TT design many moons ago.
It worked well then, hence.
P.S.Noticed how I paid attention to the spacing after the comma?😀
Hi Eric,
I thought as much.
Cone Then ?
I do not know of conical wound valve springs - only seen straight ones.
Glueing a cone to one end might be a good soloution.
They come in different weights - maybe usefull to visit a motorcycle mechanic for smaller ones.
"P.S.Noticed how I paid attention to the spacing after the comma?"
LOL 😀
Eric.
LOL 😀
Eric.
RE:Cone Then ?
Hi Eric,
Same here.
The ones on the TT looked as if they were from some automotive application.
No idea where on earth this would be used in an engine though.
I am afraid it would make the whole thing tilt sideways when loaded.
What I had in mind is a metal triangular frame with three predrilled holes in it and then fix the springs underneath with bolts to support heavy cabs.
The top should then fit flush underneath the cabinet.
In that way the springs won't get lost in transport and a product could be put out to the market after further development.
I don't dwell in those circles anymore but since you do?
Ciao,😉
Hi Eric,
Same here.
Ciao,😉
SO SORRY.
Hi Steve,
Count me in for the cheese Steve.
I did notice you guys had a small party but since I was having a Oostmalle Triple I shied away.
Thanks for the invitation,😉
Hi Steve,
Btw. the cheese is on me, just enjoy
- Tubes / Valves
- The sound of chassis?
