The simplistic Salas low voltage shunt regulator
Not a mistake, but I dare say you could also list MJE15028 as equivalent to NPN MJE15030 and MJE15029 as equivalent to PNP MJE15031. Only Vceo is different (120V vs. 150V) That's plenty for this application.
Same datasheet. Of course if someone has those. 15030/31 I had and are the most likely to be kicking around in shops or parts bin.
Any realiable source for the 2SK117GR? A vendor from HK offers them on e-bay....
The one's from Thaishine were used in my prototypes without problems, measured where they should, and in circuit the whole thing did not oscillate or look noisy on a scope.
I am considering selling 2SK117GR's as an add on to the boards if getting them in other country's will cost a lot more. The same goes for some of the other semi's if sourcing is problematic. But the whole resistor thing is variable, so no full kits.
It could be.... 🙂
Here --- look for this. Maybe you should download again. Salas has updated.
R102,202,302 270R. R106,206,306 270R/27R. 270R for MOSFET output. 27R for BJT output. 1/4W
R108,208.308 47R 1/4W
R104,204,304,107,207,307 1R 1/4W
For R103,203,303 1/4W resistors & R105,205,305 Trimmer Bourns 3296Y style, read appendix 1
Hi All,
When I connect 3 (5 volt) Sallas regs from one 12 volt Transformer I blow up a diode on the minus side, see attachment.
2 Sallas regs works fine but when I connect the third one to the DDDAC receiver board (only the 5 volt Sallas reg for the 74VHC4040M) it goose wrong.
Now I connect the 2 Sallas regs to 1 transformer everything is working fine.
I connect another 12 volt Transformer to the 5 volt Sallas reg B on the DDDAC receiver board and now are all 3 Sallas regs working.
Can someone tell me why are 3 Sallas regs NOT working with 1 Transformer?
I must connect 9 Sallas regs on 1 Transformer for the DDDAC also for the DAC towers.
Rudy
Edit: 12 volt 500 VA Transformer the right one is for the DAC.
The diodes blow up are 1N4007 now I use 1N4004 and that works fine.
The Transformer I use on the picture are without diodes 😉
I must connect 9 Sallas regs on 1 Transformer.
2off 8.4V 800mA (DAC Tower à 12xTDA1543)
3off 5V 80mA (Receiver board)
2off
3.5V 80mA (DAC Tower à 74VHC125N)
2off 3.3V 80mA (à VDD1 USB Receiver & DAC PCM2707PJT; 74HC08) (à VDD2 Tent XO Clock 12Mhz)
Here you have a PDF file: http://www.dddac.de/files/dddac1543mk2ver50.pdf
Rudy
back again 😀
today i have replaced my transformer and experimented an 12 volts Pb acid accumalator with my Salas low shunt regulator V1.0 (5v) which powers up my M-Audio Transit usb soundcard.what i remarked is a more articulated sound.why there is audible difference between those two 12 volt supplies ? or should it be ?
thanks 🙂
ps : i like the sound with the accumulator the most
