• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
The Professional Class-H Amplifier 2KW
hi workhorse
greetings thanks for the information busy trying to make 3 way active crossover fully variable with my subs the WICKED ONE decaware speaker design 2 15
inches 600 watts each thank you workhorse you are a GEM
thanking you
andrew lebon
hi workhorse
greetings can you tell a direct replacement ic for IR2117 very hard
to find or any site wich has 3 step using LM311 AND 2N3904 2N3906 transistor
easy to get and cheap .
thanking you
andrew lebon
http://www.diyaudio.com/forums/solid-state/121063-multi-kilowatt-blaster-development-2.html
Has schematics for the 311-based circuit. The project and many others have been on hold due to a severe lack of shop space. Everything's in storage - I had to tear the building down and it just now being rebuilt. Then the amp work re-starts. 😀 😀😀 The 2-step version has been working fine for gigs over the last 4 years.
AutoClass where is your schematic with values of the components?
Anyone building amps with this kind of power should already be able to calculate the necessary resistor/cap values and spec the transistors. If you can't you're asking for a pack of trouble. You don't need a degree in electrical engineering - just some experience building amps. If you want to blindly copy something, copy something smaller until you get a handle on what you're doing. Electrical fires are a real *****.
