Part Values
Schematic *IS* Complete, But without part values, for refrence only...
Until now 🙂
No complete schematic (values and all). ??
OS
Until now 🙂
Output stage can accommodate variety of pairs, I prefer MJL21195/96 pairs if an increase in output is needed.
hi workhorse
greetings can you tell a direct replacement ic for IR2117 very hard
to find or any site wich has 3 step using LM311 AND 2N3904 2N3906 transistor
easy to get and cheap .
thanking you
andrew lebon
thanking you
andrew lebon
hi workhorse
greetings thanks for the information busy trying to make 3 way active crossover fully variable with my subs the WICKED ONE decaware speaker design 2 15
inches 600 watts each thank you workhorse you are a GEM
thanking you
andrew lebon
thanking you
andrew lebon
Helo sir, i am at indonesia so hard to IR2117 can be replaced by
IRS21850,
FAN73611
FAN7371 all unit not for sale?? can be replace again?? tank you
IRS21850,
FAN73611
hi workhorse
thanking you
andrew lebon
http://www.diyaudio.com/forums/solid-state/121063-multi-kilowatt-blaster-development-2.html
Has schematics for the 311-based circuit. The project and many others have been on hold due to a severe lack of shop space. Everything's in storage - I had to tear the building down and it just now being rebuilt. Then the amp work re-starts. 😀 😀😀 The 2-step version has been working fine for gigs over the last 4 years.
Cool
Nice Amplifier, Good Work.
i think this is for sale so no values for the schematic... business 😀
Anything bad in selling pcbs?😱
In that case this thread is worthless here and should be moved to the commercial section.
OS
OS
Don't get upset
PS:Group buy will be done in commercial section only, no one is breaking the rules.
hi workhorse
greetings is it real a group buy for this amplifier would be interested if there is a group buy
thanking you
andrew lebon
thanking you
andrew lebon
AutoClass where is your schematic with values of the components?
Parts List with full detailed schematic will be accessible to those who will buy the PCB.
PCB cost is around 45~50US$, excluding shipping, While at least 50 PCB orders are minimum required in order to run the group buy.
Also Group Buy will be started in a few days. can be followed here
http://www.diyaudio.com/forums/grou...sional-class-h-pcb-group-buy.html#post2365685
3 step class h
RMX 5050 using LM311 step driver
hi workhorse
thanking you
andrew lebon
Anyone building amps with this kind of power should already be able to calculate the necessary resistor/cap values and spec the transistors. If you can't you're asking for a pack of trouble. You don't need a degree in electrical engineering - just some experience building amps. If you want to blindly copy something, copy something smaller until you get a handle on what you're doing. Electrical fires are a real *****.
- Vendor's Bazaar
- The Professional Class-H Amplifier 2KW
