The Pass Pub: The High-End Off Topic Thread
Some people use high quality Kraft paper between layers - OK if varnish impregnated. Polyester tape also works, though the dielectric constant is fairly high. My magnetics guru at the first SMPS job I had preferred Nomex paper, but he came from an aerospace avionics background and had expensive tastes. I've thought of using the same teflon tape used to seal pipe threads, as wide as you can find it. The build might be too much for decent volumetric efficiency. They make teflon tape for specialty electronics applications, but it's no doubt a specialty order item with a hefty minimum quantity order and a long wait.
Joined 2006
Dachshunds say it iz cold here in Nashville today..... down to 2f degrees tonight with a chill factor of -15f..... and that isn't even factoring in SWMBO - and she iz always good for a few more degrees of chill factor.....
