Some people use high quality Kraft paper between layers - OK if varnish impregnated. Polyester tape also works, though the dielectric constant is fairly high. My magnetics guru at the first SMPS job I had preferred Nomex paper, but he came from an aerospace avionics background and had expensive tastes. I've thought of using the same teflon tape used to seal pipe threads, as wide as you can find it. The build might be too much for decent volumetric efficiency. They make teflon tape for specialty electronics applications, but it's no doubt a specialty order item with a hefty minimum quantity order and a long wait.
nope
keeping Pole Fashion exclusive to Founder of Dodoland
like I said before , I'm always here ....... keeping The Post in Order
Smaug's Voice - YouTube
naah
I'm just giving small ones , key-chain sized , gratis with each original Pass Labs case I'm selling.
How's your order book?
Keep doing that and you will be lying under a stone [saying "ZM passed away"]
rather than sitting on one!
Dachshunds say it iz cold here in Nashville today..... down to 2f degrees tonight with a chill factor of -15f..... and that isn't even factoring in SWMBO - and she iz always good for a few more degrees of chill factor.....
Hell looks frozen over....as you will be if SWMBO reads that post!
Say "hello from Scotland" to de dogz.
- The Pass Pub: The High-End Off Topic Thread
