tried to PM him "Josh Ricci has exceeded their stored private messages quota and cannot accept further messages until they clear some space." 🙁
Ive sent emails, just waiting ^__^ so excited i can barley contain myself. Have to remember to calm down when i start building lol. Anybody in or near MI have othorns?
Aaron,How would somebody go about getting the plans for the othorn?
The Othorn plans are in post #2, the exterior cabinet width is 24".
Art
What is the weight of each of these I see on the data base it's 240lbs but on the ProSound Web it says 115lbs unloaded? Thanks
The cabs are 36x36x24" and are around 115lbs unloaded so these would obviously have to be freight shipped. The cabs do have some gouges and scrapes from being moved. That goes with the territory. I have a list of the drivers that work well in the cabs and also adapter plates to fit 18" drivers or 21" drivers.
Josh what size T-nuts are used on the woofers on these as I'm having 2 built and want to make sure that is correct ? ThanksDepends on the drivers but it should be somewhere around 140-160lbs with the driver.
Thank you sirIIRC Josh used a different type of #10 threaded insert, something like this:
They are set to be delivered on the 22nd of this month pretty excited also wondering how they will sound compared to my Danley DBH218.
JBL 2241H Speakers Link
Would this would work in an Othorn?
I can get it used for $200 each.
Or should I just save and wait a bit for B&C 21SW152?
Thanks,
Jeff
Thanks,
Jeff
Thanks for the info Dan.
I wonder if there are other horns these would work on.
I will keep searching...
Hello, do you hapen to have the pdf for the othorn woofer? If you do wat will it take to get a copy?
- Subwoofers
- The Othorn tapped horn
