Sorry, I'm probably being dumb, I can't get my head round that. Do you mean equalising the spectrum so it sounded flat?
Yes but equalized against the hearing curve of your own ears.
It would probably sound pretty nasty.
Not really. I tend to not capatilize lots of things. My company name for instance. Perhaps a lowercase “i” has less ego in it.
Yes sir!
It is, by doing an actual EEG as a data result should makes things clearer and takes the listener’s perception to vocal or written interpretation out of the equation.
dave
Egads no, evidently you haven't seen how noisy and coarse EEG data is. Utility of EEG to audio testing is purely in making marketing gobblygook.
PS, hope you are healing well.
Correct, I did it years ago, when I thought it was a good ideaYes but equalized against the hearing curve of your own ears.
I doubt they can do that without first having you look at each picture in turn whilst they monitor and record the results then subsequently have you look at them randomly and compareResearchers can have you look at a series of pictures while hooked up to a brain scan, and tell which picture you're looking at from the brain scan.
Conventional designs lead to 'audiophile neutrality' when done to perfection but they sound wrong. 'Bright, warm, bassy' work to compensate for shortcomings for a system that was never right to start with, and doesn't fit with the room, and adds issues that veil the recorded material.then discovering that the technically ' perfect ' equipment you own bores you to tears simply because shock horror you actually prefer a ' bright , warm , bassy , etc ' sound far more than than the
impeccably neutral ' audiophile ' one that someone else insisted is the only way you can possibly enjoy music .
With an accurate system I find them to be negative attributes. It's as if 'technically perfect' is code for 'gee, I expended so much on this I need to justify the effort'.
Perhaps failing to follow normal conventions has more ego in it? Omitting capital letters seems to be a modern fad.planet10 said:Perhaps a lowercase “i” has less ego in it.
Translation: "I don't like high fidelity sound reproduction; I prefer the sound to be modified to suit my personal taste".AllenB said:Conventional designs lead to 'audiophile neutrality' when done to perfection but they sound wrong.
I’m sure vacuum dressings were only a fabtasy a decade ago — they sure work well today.
dave
No doubt there's plenty of improvements to be made, but you're essentially asking for CERN's collider to be fit into a basketball court. There's going to be a better way to move forward than ostensible miniaturization.
But I digress. Are people talking about this myth of flat reproduction before or after the room gets a hold of the sound waves?
Investments will be made when there is a need for it.No doubt there's plenty of improvements to be made, but you're essentially asking for CERN's collider to be fit into a basketball court. There's going to be a better way to move forward than ostensible miniaturization.
Yeah, lets improve the facsimile technology so that it can be faster and print higher resolution.
You guys just don't get it, which is understandable given you weren't paying attention to what I was carefully talking about. We're talking gigantic magnetic structures in this specific instance (colliders, MRI machines). Where are the new super-ferromagnetic materials? Notice how I was talking about machines requiring superconducting magnets? And how, as we move to higher and higher resolution MRI machines we need higher and higher magnetic fields, which has resulted in bigger and bigger MRI's. And still the voxel size is pretty big. Same thing goes for more and more energetic colliders.
As I said, if measuring the inside of the brain is the goal, then there's going to have to be a better way figured out. Not everything is neatly scalable.
Great. I would like to find out more about how the experiments are conducted, particularly details that may be omitted from publication for whatever reason. Might be very interesting.
Thanks for the prompt, so let me review and clarify my statement.
Several years (decades?) ago my wife and I did a blind study of the audibility of nonlinearity - the root cause of both THD and IMD. What we found was that there was no correlation between either THD or IMD as far as audibility goes. In other words some THD at 20% was inaudible while some THD at .1% was highly audible. So yes audible nonlinearities do exist, but neither THD or IMD can identify them.
It turns out that nonlinearities are most audible when the signal is low, i.e. when the nonlinearity is of high order and occurs near the zero crossing. The classic here is crossover distortion in an amp which is highly audible. (High orders of nonlinearity are very rare in loudspeakers because it is a mechanical system.) Low orders that occur dominantly at high levels are not audible even at %'s as high as 20-30. Examples of this would be BL product limiting in a loudspeaker. It can be shown that a soft clipped system actually sounds cleaner than a hard clipped one for the same level of clipping.
None of these effects can be resolved by either THD or IMD and as such these measures are pretty well useless for quantifying sound quality.
As to the argument about not being able to measure what we hear, we clearly can measure the vast majority of what we hear including imaging and probably dynamics (although you will have to objectively define this later term in order to continue talking about it.)
The main take-away of Toole and Olives work is that they can quantify 90-95% of what ALL blind listeners will perceive. Now one can argue that they fall into the 5% that hear better than others ... but I would rebuff by saying - That may be true, but then your opinion is of no value to the rest of us (the 95%.) Further, that 95% says that neutral frequency response with a neutral DI (for loudspeakers) is what matters most. THD and IMD do not enter into the picture (for loudspeakers) although to some extent the directivity enters into the picture in regards to "imaging" (not something that Toole makes many claims about.)
I truly believe that there are different design requirements for people who prefer in-venue recording like symphonic etc. where a wide directivity will help to enhance spaciousness, but tends to degrade imaging. If you (like me) prefer studio work then a narrower directivity in a more lively room will enhance imaging (spaciousness then comes from the room not the speakers.) So there may not be an ideal fro all, but the range of variables is narrowing considerably (IMO) down to these two types of preferred recordings.
I didn't mean any controversy by my comment, I just noticed that the cap I issue is common with folks that are normally careful. I have medial nerve damage in my right hand and I was just wondering if the standard keyboard causes issues with some of these normal aging problems.
The brain is so complex with a staggering number of connections it's probable that it'll never be fathomed
My brain is simple and i'm only trying to elude my room resonances.
My answer is to be simple.
Have you by any chance noticed the spelling issue too? It's common with folks posting on internet forums.I just noticed that the cap I issue is common with folks that are normally careful.
- Member Areas
- The Lounge
- The only ''definitive'' answer in this Subjective world is...
