It takes some time to scan the inputs one by one, so it is impossible not to have a small delay to select the correct input.
How much time is takes until Fusion will switch to a new source when current one will mute?
For me - it does not happen at all 🙁 I stop playing via spdif and start via analogue - silence for minutes...
10 seconds. Works fine here.
Which sources do you use?
Does it make sense for me to adress this to support to troubleshoot? Same for invert.
And same for failed rendering of comboboxes, i understand it works somewhere but i have a corner case then... this is what all bugs are about.
Had the same problem and contacted Hypex support. They can send you a special softwaretool via e-mail to solve this. You have to enter the serial number and it programs the configuration into the FusionAmp. Be careful to enter the correct serial number. It will not program a module when a serial number is present.
Configuration went ok. I have now 3 channels. The tweeter channel seems to have lower voltage gain (about -6dB compared to the other two). Is this correct or am I doing something wrong?
I also bought one FA252 for bass drivers in my 4-way system to save some money. It seems that was a mistake, because I can't set FA252 to Left ch in one channel and at the same time Right channel in the other? (SPDI/F input)
I noticed similar issue! was a bit puzzled why twitter so quiet and no attenuation required.
That's normal due to the gain difference between the amp modules.
Hypex reduced the gain of the NC100HF by 6dB to improve SNR but did not yet update the datasheet.
You could connect both L+R to the FA252 and use the bass drivers in mono. Usually when the Xover frequency is low you don't loose much information
Or, as I had to do, buy a second amp...
If you sold the FA252, and replaced it with x2 FA122, and ran them bridged you would have 250w available for each channel, and only about 90 Euro more?
Yea, I am running mono below 120Hz, but I will order a second plate in the future.
The difference in voltage gain should be reflected in the software in some way. It complicates things.
Why would this be confusing? If I take a DLCP ( or minidsp) and a 500 watt amp for low, 250 watt mid and 100 watt high ( and they need the same input level for max power) there will be gain difference between the channels.
Is this how it is? My understanding was that all NC 500W, 250W and 100W have about 26dB voltage gain so you will get the same voltage from all three amps and the 500W will require more voltage to clip than the 100W?
When you start to add and subtract 6dB in software for one channel it gets more complicated. Espesially when optimizing the gain. You have to remember the 6dB. This is my opinion.
Is this how it is? My understanding was that all NC 500W, 250W and 100W have about 26dB voltage gain so you will get the same voltage from all three amps and the 500W will require more voltage to clip than the 100W?......
That only holds up if all drivers have the exact same efficiency. Otherwise you are still trimming input levels to match acoustic output.
Measure!Is this how it is? My understanding was that all NC 500W, 250W and 100W have about 26dB voltage gain so you will get the same voltage from all three amps and the 500W will require more voltage to clip than the 100W?
I have 3x200w for both tweeter, midrange and bass(they all have different sensitivity) - then 700W for subwoofers. But when my tweeter is 8ohms and 110dB it is of course 200W, but when my bass is 93dB and 3 ohms - things can get interesting. All I have to do is measure and adjust individual volume settings in my pre-amp or software(DSP). Never thinking of numbers as such, because when I use a lot of EQ on my drivers, I end up with a new level of SPL for a given input. So I measure each driver when I finished EQ'ing them and then attenuate the total level, so that everything match - easy 🙂
I has nothing to do with driver sensitivity. It is just that the relative levels of voltage output between the amps does not match in software vs measuring the output. It would be nice if it did. In my experience it is more easy to handle such a system
- Class D
- The New Hypex Fusion Plate amps
