I drive my Fusion digitally. I have the impression that sound is improved if I attenuate sound 1 or 2 dB (from 0 dB), though i am not 100% sure. I would need to do more experiments to be fully sure. Could it be that the resampler at input of Fusion clips when driven with 0 dB level & loud music?
In this case, the only thing that comes to my mind is an implementation with a frequency dependent limiter that keeps woofer excursion within the systems capacity for higher output levels. Something that would be typical for designs utilising dsp to get very low bass output from small woofers.Wow, I never ever heard about that effect. Why would the DSP controlled speaker have significantly different bass response at different SPL?
Maybe one thing comes to my mind, a level dependent loudness effect, which can be programmed into the DSP.
But the FA DSP doesn't have such a feature.
Any other thoughts?
Devialet Phantom is a design that have this feature.
Johan-Kr
Yeah, a woofer limiter seems more realistic than an equal loudness control.
I’m always wondering why they push so low those little woofers in the spectrum.
By now I have come to agree that his mention is only directed to the consumer who does not know that the speaker might be highly automated. There are reviews of Napilopez in which he mentions the boldest DSP programs working at different SPL levels. So that is this.Remember that Napi is reviewing speakers more than designing them, so it's a bit different than someone setting up a Fusion.
But I remember when I changed limiter settings in FA123, the frequency response also changed slightly, albeit that the limiter was only set to work at an very high wattage to protect against serious user operation error. A turned up volume knob, some signal coming from outer space (computer system sound), you know... As I run the speaker at something like <0,1 Watts most of the time, I was a bit surprised to see the limiter have an (linear) impact on the overall response (slightly reduced output) even when the signal was waaay below threshold. Of course, if it is set to a certain level once and the DSP/frequency response is corrected on this basis, this would not be an practical issue. And it was still at the beginning of my endeavor, user error/misunderstanding cannot be ruled out.
Fedde, what is your digital source before the Fusions and where you adjust the volume?
PC with JL sounds USB to SPDIF (vIII), Ultrabib V3 supply. I adjust volume via Hypex volume control. The -1 dB I do in the audio application in use.
Yes. Notice how frequency response below 60Hz changes when increasing volume.
That may be some kind of rounding error in the USB to SPDIF converter or USB audio driver. Do you have some other source to try?
How to sync volume between two plates?
Looking to rip the guts out of some old meridian speakers. If I replace them with two FusionAmp FA123s, how do I sync the volume between the two plates with a single remote control?
If you want to use the Fusionamp remote controller, the amps need to be connected together via S/PDIF RCA cable for master-slave operation. Check the manual.
Oh I had missed that! That is quite clever. Thanks!
Guys, any updates on what will be in scope of FIR functionality ? Will it be available on new devices or old fusion as well?
I noticed one thing on all four Fusion amps in my possesion. Maybe is mentioned before but cannot recall.
When using EQ on any way the amp sending some kind of signal to drivers. I did not notice before I connected subs which produced sound, very tiny but hear able. After, I have checked all amps and all are the same, but the signal is on so low level that is noticeable only with ear on driver.
Is it there any fix for this issue? Maybe new firmware, my is 1.41.
Just upgrade to latest version and report back. I think there were indeed reports of idle noise with older versions by the way...
somewhere in my memory I have note about same problem but cannot recall.
It is not ground loop, It has no any pattern and is is going from couple of Hz (I can feel it when put fingers on diaphragm) till maybe 1500-2000. I cannot hear it through tweeters, but mids and woofers.
I will upload firmware tomorrow and report Sir🙂🙂🙂
Updated
no anymore strange sounds. Now I can hear tiny, tiny ground hum. probably was masked before.
Thank you again
Thank you again
- Class D
- The New Hypex Fusion Plate amps
