The M2 Output Stage in Class A/B, and maybe a Power WHAMMY?
150W
Reactions: TNT
This version is still local feedback and M2OPS is not in the feedback loop (post #26).
Once you include the OPS in the opamp feedback loop (post #24), the distortion will sink to opamp level.
But different sound.
Ideally you should use brass screws and also solder the screw head to the bottom side.
Patrick
Reactions: Extreme_Boky
Not surprisingly, the above measurement corresponds to what we published before :
https://www.diyaudio.com/community/threads/complementary-power-mosfets.378024/post-6889027
https://www.diyaudio.com/community/threads/complementary-power-mosfets.378024/post-6888301
So if one is to go for the local feedback option, the ideal candidate for the MOSFET pair is 1SK3497/2SJ618.
Apart from much lower distortion, they also allow output swing closer to the rails, due to their much lower Vgs at bias.
Patrick
My small flat is heated with elctrical radiators. This could double as one with the advantage that this makes music i.e. a happier life 🙂
May I ask one more thing - what cooling capacity do I look for in a stereo cabinet?
