I took the mounting rings off to see if it made any difference, and it did, the soundstage seemed to open up a bit, and the sound smoothed out a little bit more.
I also addedd a little more wadding around the area the wires run since I noticed a slight rattle at higher volume.
The crossover was a standard cap and inductor setup, but the usual low quality stuff. When I attached the binding posts, I decided that I would make them bi-wirable, so when I attached an active crossover and seperate amps for each driver, I noticed quite an improvement.
Like I said, car speakers were not my first choice, but they were there, so I thought I'd give them a go.
I love the design of the frugel-horn enclosure, its quite elegant and performs extremely well.
At some point I might try some different drivers, to see what differences there are in the sound, I have a few others lying around, but for now, I'm more than happy.
Building these speakers was a very enjoyable experience, the plans were really easy to follow.
CossieGlyn said:so when I attached an active crossover and seperate amps for each driver, I noticed quite an improvement.
That is not surprising at all 🙂
dave
I have just added a slide-show of the build of the prototype flat-pak that Chris & did last fall.
http://p10hifi.net/tlinespeakers/FH/FH-build/FH-build.html
dave
dave
Joined 2002
planet10 said:I have just added a slide-show of the build of the prototype flat-pak that Chris & did last fall.
http://homepage.mac.com/tlinespeakers/FH/FH-build/FH-build.html
dave
Is this the speaker that i tested at home ?
No... those are now finished and for sale -- i'll take some pictures. They are quite pretty.
These are having the FF125 installed so that we can optimize for it and evaluate it.
dave
dave
Joined 2002
planet10 said:No... those are now finished and for sale -- i'll take some pictures. They are quite pretty.
dave
I really liked them the way they were when i had them. What is the price ? I was definaly considering a set when i borrowed them. Just needs a Ribbon on top ( my opinion )
Picture,
All the main pieces anyway. No baffles, deflectors, pr supraBaffles. All cut, but need detailing.
dave
dave
Sorry & apologies to all, i've had many life-changing events that happen and prevent me from proceeding with my projects, but will try to slowly get back on the horse...
following this post:
http://www.diyaudio.com/forums/showthread.php?postid=978777#post978777
These 3/4" layers, "Europly" has 15-plies, Maple B2 skin, 99% void free, ~ $109 USD for a 4x8
Clamps galore:
Baffle & Base:
Clamps galore:
Baffle & Base:
Heck yes! How to stick it to Gemme audio with their MDF and ~$4,000 pricetag for a smoothed version of Fostex's own enclosure (which they have the brass face to say they designed) in one easy lesson! Want some, want some!
planet10 said:
How many sheets?
dave
I'll have to check my layout sheet... have chicken scratch everywhere
Thanks to everyone for all the great comments
Scottmoose said:Heck yes! How to stick it to Gemme audio with their MDF and ~$4,000 pricetag for a smoothed version of Fostex's own enclosure (which they have the brass face to say they designed) in one easy lesson! Want some, want some!
OT: I've yet to build another pair of Ron's Austin II & also a layered A126 already in progress...
The ply is just all around much better quality build than MDF but comes with the cost...
- Full Range
- The Frugel-Horn Project
