• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
The free Blacksheep Kable demo test
OK here are some pictures. First off the wire is from this manufacturer.
Welcome to Thai Wonderful Wire Cable just plain ol hookup wire.
all the pictures can be seen here, Picasa Web Albums - Jase - Blacksheep Ca...
infact its 1007 wire from them.
UL 1007 Hook-up Wire
Applications
For general purpose internal wiring of electronic and electrical equipment
Product Description
Tinned, stranded or solid copper conductor, 32-16 AWG
Color-coded PVC insulation
Rate temperature: 80° c. Rate voltage: 300 volts
Passes UL VW-1& CSA FT1 vertical flame test. OS-1 is available
Uniform thickness of wire to ensure easy stripping and cutting.
Resistent to acids, oils, alka;ies, moisture and fungus
U said monster EWWWWWWWWWWWWWWWW!!!! hope you got them free !
I have a variety of interconnects. I had forgotten this Monster M350i which I'd bought years ago in a corner, since I'd removed its shielding foil just as an experiment, and in the system I had at the time doing that didn't improve its sound quality as I recall.
But I came across it lately and thought why not give it a chance...it's a braided solid core with nice dielectric & good plugs, after all. 🙂
It turned out that, coming after my Audioquest King Cobra, it sounds even more transparent?! Well I still have to switch back and make sure 🙂 but I know I like what I hear, so I'm keeping it for now! I've even considered terminating this Monster M350i braided internal wire with some new RCA plugs I have, since I think the wire deserves the effort 🙂
OK, it seems like you're right about the wire. :dead:
Tinned copper is better than silvered copper, no doubt 😉
The theory is that outer plating should be of lower conducting value than the core
In other words "slower"
PVC is ok too
I would certainly hesitate to choose teflon over PVC
Besides, many cables are about construction, just as much as materials
I bet the construction and design will influence more
Partly why I prefer thin and simple cables, less influence on sound
Soldering of ground wires does look bad or even dangerous
Its obvious that the amount of wires makes soldering problematic
And I really have no idea why a signal interconnect should be built like a speaker wire
PVC is ok too
Yeah, soldering of ground wires looks bad in the sample jleaman showed us.
Well... the theory may be that, but somehow I like silver plated copper, as it conveys to copper that slight more "edge" it sometimes just needs. 😉
Anyway I'll just try to hear the cables (which are waiting for me at the post office) without prejudice regarding the wires. 🙂
