The food thread
The problem is the sausage/pork diet is not exactly the best for your physique.
Surely. I guess meat is more of a "special occasion"-ish thing for me, so I take that for granted.
Cal - some sort of al/ti/si- oxide or nitride. It's a ceramic coating, no Teflon, but also low surface energy (nonstick) and as long as the adhesion is good to the substrate, very durable.
Hi Daniel,
I have T-Fal pans. They're Teflon. I also have a ceramic pan. Nothing similar.
The T-Fal site says it's PTFE, every other site says it's PTFE. You can read that TEF is for Teflon and AL is for aluminum. You can read about DuPont's patent and the Tefal (T-Fal) use of it and why there are two different spellings... it goes on.
What I would like to see is something that says it's not PTFE. The only difference I can see is that there is no PFOA used in the manufacturing. So? Many are made that way nowadays I believe.
Just curious.
Sorry, Cal, didn't do due diligence. Other manufacturers that make nonstick non-Teflon (or, generally, PTFE) use ceramics as I described. Also, could be something about how they prepare the surface to take the Teflon coating.
We'll have to consult the expert on this one. 🙂
My electric stove is aging and the burners (solid, non-replaceable) take a long time to heat up. One has died, as long as I have one large and one small I won't replace it 😉 A bit like this one: http://www.chowstatic.com/uploads/2/4/9/1025942_image.jpg
Wish they still made these, all you can find are coil or glass-top ranges now.
benchtop+hotplate
The portable ones here are 240V and 2400W...very handy for cooking/warming next to the bbq.
It might be worth a look to see if these are suitable as parts donors to your kitchen cooktop ?.
I seriously like my cast iron better than any teflon pan I've ever used. I used a Bialetti non-stick for a while (my emergency pan) and stuff sticks to it.
Yes, nothing beats heavy cast iron pans...the ones with integral cast iron handle are the best, kitchen and bbq.
Dan.
benchtop+hotplate
Dan.
You can have an electrician wire an outlet that takes this in the US (L1, L2 and cap the neutral (NOT the safety ground)). You then just need to replace the plug with the one that has the prongs at 90 degrees (>1800W).
Looked forever for it, there are some from NZ and Europe. If your up for it there is a two burner 4KW commercial drop in that can use a residential hook up goes for $700 though. Most other commercial ovens I found use 440 three phase connections.
The range I have has the so-called "euro-style" burners that I believe are only replaceable as the entire set at a time. I'm told that parts are no longer available. They are really nice because stuff never leaks down inside like on a coil unit or a gas stove. It also doesn't get scratched or look dirty all the time like the glass tops can. Before I spent big bucks on importing/rigging something I would probably just go for an induction range or cooktop.
I really prefer gas but I don't really want to pipe gas to my kitchen. I'll have to run some numbers to see what size pipe etc...and whether my supply line is big enough. I have a big tankless water heater, the incoming water is quite cold in the winter ere in MN 😉 Maybe I can have a plumber rough in something (maybe a "T" for the laundry while he is at it) when doing something else.
