The food thread
Another simple tortilla pizza success.
Standard NA 'Deluxe' toppings.
Fermenting idli batter is easy, just keep it about 25-30 C for 12 hours...and a slightly sour smell indicates proper fermentation has occurred.
Stir before using, refrigerate what is left over, use within three days.
It is rice with a little udad daal added, just soak and grind, use it later.
If you get par boiled rice, better.
Many recipes on line...
Similar batter can be used for dosa, vada and uttapam.
Alternately, get rava idli powder, add sour curds (instructions on packet), and leave it at 25-30 (room temperature) for 2 hours, and steam...
Third...we get idli batter here, use it...ask a South Indian friend.
We use ghee as a release agent, applied with the back of a spoon to the steamer, brushing might be more handy for you.
There is a famous restaurant called 'MTR' in Bangalore, I use their Rava Idli powder, among other products.
Result is close to what they serve in their restaurant.
There may be other brands available, no ties to MTR except as a happy customer / user..
Room temperature is generally 15 to 18C.
A lot of us forget that an auxiliary heater used for dough not only adds the needed temperature, but the excess is returned to the room for creature comfort. Same with leaving the bath water in until it cools to room temperature. The bathwater trick also helps with static when it's clear and cold. Simple stuff. What comes around, goes around.
One might be tempted to fire up that class A amp and listen to something while the dough rises...
Reactions: Cal Weldon
Found a lonely tortilla looking at me with malcontent so I found some more of the same disgusting good food I have been eating recently. As you guys know, using up what we have created is quite a chore when friends and family have taken flight to warmer locations this time of year. The last pic appears unfortunately dark. Not the case, I am using my pocket phone. The fry pan was used to make sure the poor tortilla still had life.
