The diyAudio Firstwatt F6
If you have the luxury of 4 test meters so as to get the F6 upto temp and even bias and offset this is the best way to do it.🙂
Perhaps this has been asked somewhere in the myriad F6 threads, but...
Has anyone tried to build the F6 with some resistance between the drain of the bottom FET and output? I compared a SPICE simulation of the F6 with 0.47-ohm source resistors to the same circuit with 0.235-ohm added between the drain of the bottom FET and output/0.47-ohm source resistor of top FET and the (simulated) distortion dropped by a startlingly large number. The harmonic profile also changed to be more 'pleasingly' 2nd-harmonic dominated.
I'm getting cancellation of 2nd Harmonic but 3rd Harmonic is staying the same.
hrks, i just came across the hint 6L6 and generg gave earlier, just to feed the amp with a 1000 Hz signal (from i pod) and, across a 4-8Ohm Loadresistor go to the computer. The Software i used is Sine Scope.
totally uncalibrated, i just made a bit louder to see anything. looks quite bad doesent it? Don´t know if its the amp or a fault in measuring.
Maybe the ones who did this, could you share some settings.
tnx
st.
Hello!
Just built myself an F6 amp! everything works very well, no magic smoke and everything went very smoothly.
However the bass quantity (not quality) is a bit weak, kinda sounds like "puff" instead of "omph" when some electronic bass transient are playing.
I had the same thing happen with the F5 i built, so i'm starting to think that this type of amplifier is not right for the speakers i have (Focal electra 1028Be) They are quite efficient at 90-91db/w and nominal 8 ohm.
When i use some 200W/ch@8ohm amp there is quite a lot more bottom end speed and "omph" but the mid and HF on the F6 is for sure better and it images a lot better too.
Anyone having experience with this kind of setup?
EDIT: Because i have some matched pairs of the 2sk1530/2sj201 combo i used them in both project (2xK1530 in F6 ofc.) But doubt they are to blame for low bass quantity
EDIT2: Was thinking it might be possible to throw in another output pair and up the supply voltage a bit, to say +-32V but that would put the input JFETs at risk so was wondering if it might be possible to use a slightly modified circuit as to my superb windows paint drawing 😉
Using resistor in modified circuit, but of course one could use some more exotic, like a voltage regulator here, this keeping the input JFETs at say +-22-23v.
