So, its not exactly DIY but if you put a sub on this baby you could probably call it a Boominator giga
Trailer Mounted Mobile Speaker Tower, Diesel Generator, Solar Panel, Battery | Ramco UK LimitedRamco UK Limited
Check out those horns.
That's the sort of thing you find when you hunt for surplus solar panels....
hello!
I´m new here, I would like to build the boominator mini 150x150x450.
I have the drawing but not the part list.
help someone 🙂?
help someone 🙂?
Okay not exactly finished!
Still need the lid! Handles in each end and corner protectors! 😀 !
Why not just a long handle down the middle?
And good job btw.
Ive been trying to adjust the dsp settings of my s2010 + pht 407n for the last couple of days, but cant seem to get it right, it still sounds distorted in the midrange.
Im currently using a high-pass at 2000Hz LR 12/dB for the tweeters
and low-pass at 1400Hz BW 12/db for the woofers
tweeters gain -2dB and inverted polarity
am I doing something obviously wrong?
Hello!
I have been having trouble finding 3W 33 or 47 ohm resistors. Instead I am planing to parallel couple three 1W 120 ohm resistors. Am I correct that the values will become 40 ohm and 3 watt when doing like this or am I completely wrong?. I also wonder if 40 ohm is okay considering the recommendations is 33 or 47 ohm. I am using the Monacor Mpt-001.
Many thanks!
Many thanks!
Just double checking before buying.
I have understood that a PTC fuse i recommended, and the AMP6 peaks at 4,2A, so this PTC fuse should fit the bill?
https://www.elextra.dk/main.aspx?page=article&artno=H15564
Thx.
Thx.
I tried to find some information in the vast history of this thread and came up with the following posts by Saturnus. Hope this helps a bit.
Post #2163
You need a 2nd order Linkwitz-Riley high-pass at 2000Hz and a 2nd order Butterworth low-pass at 1400Hz. Which together with the actual frequency response of the drivers gives an acoustic 3rd/6th order Bessel filter at 1800Hz.
Remember to invert the tweeters and dampen them by 3dB with a series resistor.
Post #2164
Here's a simple and fast drawing of how it should be connected. Please note that I made a mistake. The plus on the tweeters should be connected to minus on the amp, not the plus on the amp as I have drawn here.
http://www.diyaudio.com/forums/atta...nother-stab-ultimate-party-machine-filter.jpg
I have bought 2 x 015W/12V solcelle ETSolar M53615 Mono, KeryChip WEBSHOP - solceller, solcelleanlæg, tilbehør and i really would like some other panel that fits (smaller) the boominator size better. I bought these in 2011 when i starter my project. Anything new that fits the boominator better ?
/donnib
/donnib
Those settings are for a passive filter. Will not work with an active filter.
Try the DSP setting listed one or two pages back for the HP10W+PHT407N combo and adjust from there.
Donnib. 5 times this solar panel on top of the mini:
1 5W Solar Panel to Power Cell Cells Charger DIY 12V | eBay
Total of 7.5w for 50 bucks excluding shipping.
Seems small, the one i have is 15W max and i have two yelding a total of 30W. My biggest issue with the one i have already is that the frame is thick and i can't seem to take out the glue so i can remove the frame. If i could remove the frame these would be perfect. Maybe i shoul just accept the frame.
Isn't it a better idea to search for a CIGS panel?
I guess so but seems expensive.
- Class D
- The Boominator - another stab at the ultimate party machine
