I like the look of the impedance curve of this model@jwags81818
For the 300B I am using Rod Coleman's filament supply which, according to many, performs really well.
I also made other variations compared to the original circuit:
- DC Filament + LED bias circuit for the D3a
- Fixed biased through an external negative supply (whose value can be set with a trimmer) for the 300B
- Monolith Magnetics custom OPTs based on the SX-11 nanocrystal core (I have high expectations on these)
- Replaced all the electrolytics with high low ESR DC-Link caps
- 2.2 uF Duelund CAST Cu-Sn coupling capacitor (I love Duelunds)
I am bulding the circuit in sub-blocks so I will be able to replace any of the sub-block at any time and try for a different circuit.
At some point I'd be curious to try the high frequency AC filament supply, but it's something that I am leaving for the future
Thank you for the suggestion about the LinLai WE clones, at $699/couple the price seems very reasonable if they perform as good as the original WE!!
Which 106db/W loudspeakers are you using? .. as my next project I was thinking about building some speakers using lil-audio drivers.. or maybe have them built by someone else, because I am not very good at cutting and gluing wood ..
https://www.lii-audio.com/product/o...total-full-range-and-exquisite-sound-fast-10/
That is something to keep your eye on when deciding. Of course listening is paramount but when that isn't possible a flat impedance curve will let a tube amp sound its best.
L1... L4 is an interstage push-pull transformer. They are connected by the K statement.What is the function of L3 and L4? I have never seen this before.
Bear with me here... So its coupled thru this transformer. The L1 and L2 being driven by the first stage are driving L3 and L4 to provide input to the output stage. Is this correct?
I have heard several amps that were dead silent with 90spl speakers that weren't with my 106spl speakers. The owner said it was silent on his system at home. Thats all I can go by. I have no other experience with that amp. Highly sensitive speakers can bring out noise that otherwise went unnoticed. Not that there needed to be something wrong with the amp. It's just the nature of sensitive speakers. They are less forgiving of such things
Will add this - EL84 PP amp with 89dB effficient speakers was dead silent.
The same amp with 96dB eff. speakers - I can hear its noise floor easily with ear in the big 12" wide mid horn.
Correct 👍Bear with me here... So its coupled thru this transformer. The L1 and L2 being driven by the first stage are driving L3 and L4 to provide input to the output stage. Is this correct?
grovergardner said:
"That Elekit shouldn't make any noise at all. He might have a grounding issue or a bad filament regulator. I've heard one that was professionally assembled and tuned up, and it was dead silent."
I have heard several amps that were dead silent with 90spl speakers that weren't with my 106spl speakers. The owner said it was silent on his system at home. Thats all I can go by. I have no other experience with that amp. Highly sensitive speakers can bring out noise that otherwise went unnoticed. Not that there needed to be something wrong with the amp. It's just the nature of sensitive speakers. They are less forgiving of such things.
I guess that's a fair point. ;-)
kmtang,
What a genius circuit!
Correct me if I am wrong, please.
I could not expand your schematic in Post #55, therefore my analysis of your circuit may be wrong.
It looks like you are sending an unbalanced signal to:
A CCS and parallel cathode coupled phase inverter/driver input stage, which inverts the signal and applies it to the push pull primary of an interstage transformer.
The interstage transformer secondary is connected in phase, to provide an unbalanced signal to the 300B grid.
The advantages of your circuit are:
The interstage transformer has balanced current in the primary, so the laminations do not need an air-gap (less turns, smaller wire length, less laminations, and tighter primary to secondary coupling).
The input stage CCS and cathode coupled circuit reduces the 2nd Harmonic Distortion (at least partially cancels the 2nd HD).
Since the 2nd harmonic distortion has been reduced, there is very little interaction between the driver's low 2nd harmonic distortion with the very 300B's very moderate 2nd harmonic distortion.
This seems like a real good way to get that single ended sound!
Was this your purpose?
To avoid the large reduction of the total 2nd harmonic distortion.
In a practical way, the only 2nd harmonic distortion that is heard is from the 300B.
Correct?
If I somehow understood your topology,
Then I would be interested to know how many other readers noticed or understood your very interesting design.
Readers, speak up please!
It is a Mean thing to say that Karl Friedrich Gauss was an Average man, who was Centered on his Gaussian Curve.
Correct?
Hello 6A3summer,
Yes, your understanding is correct. Thanks for your detailed explanation of the circuit. In fact, the driver stage can be switched for either RCA or balance in. The driver stage gain is reduced by half with RCA in. A line input transformer can be used to convert the RCA input to balance. Also, we can use either 1:4 or 1:5 transformer if extra gain is required.
The PP driver stage provides exceptional low harmonics for both evens and odds. I am so surprised that the amp sounds so good from this PP=>SE amp. The friends were amazed how nice it is.
Johnny
Johnny
- Tubes / Valves
- The best sounding 300B SET amp I have ever heard.
