Hazard500: flip-flop x1
Supra: single-ended x1
Stijn001: flip-flop x1
dwjames: single-ended x1
ichiban: single-ended x1
PJotr25: flip-flop x1
Pegasus21: flip-flop x1
skrstic: flip-flop x1
Snicklefritzz: please specify type required
flowerpot: flip-flop x 1
Umarcus: balanced x 2
Giulio: flip-flop x 1
Caad: balanced x 2
randytsuch:balanced x 1
deanoUK balanced x 1 SE x 1
Vdi_nenna: single-ended X 2
merlin el mago: single-ended x 2
Nikola Krivorov: single ended Х1
pgour : Flip_Flop x 1 + SE x 1
ligascon: balanced x 1 SE x 1
matejS: single-ended x 1
analog_sa: balanced x 1 SE x 1
lukaluka: flip-flop x 1
xaled: single-ended x 3
Anjump123: Single-ended X 2
asanden: balanced x 1 + SE x 1
whmok: single-ended x 2
JimS: balanced X1, single-ended X2
Caad: balanced x 2
flowerpot: flip-flop x 2
Caad: balanced x 2
Caad: balanced x 2
Caad: balanced x 2
Guglielmope: balanced X1, single-ended X2
Caad: balanced x 2
Caad: balanced x 2
iestynrw: balanced x1
Caad: balanced x 2
I had a small packet arrive today...
...the first batch of the revised single-ended boards.
I'm aiming to make one of these up and test it over the coming weekend.
Also, the parts I'm waiting for to finish the flip-flop prototype are now on the way so I should be able to get that tested next week too.
Ray
Ray is possible to buy the B.O.M togheter the pcb?
Felipe
Ray is possible?
I've got a heavy cold so haven't felt like making as much progress as I had planned. I have managed to assemble one of the new SE boards but haven't installed it into my prototype project to test and audition it; hopefully in a day or so.
I have been pondering the question of PCBs or kits. Everything needed to build one of these projects is easy to obtain and I don't really want to spend my time putting kits together so I think I'll just supply PCBs. I hope that isn't too much of a disappointment.
As you can see from the pictures, the PCBs are largely self documenting, with part numbers and values printed on the PCB wherever possible. I'm working on a separate BOM and some assembly notes for each of the boards.
Ray
Felipe
Ray
Caad: balanced x 2
torb: balanced x2
Caad: balanced x 2
torb: balanced x2
Snicklefritzz: balanced x 1
Caad: balanced x 2
torb: balanced x2
Caad: balanced x 2
torb: balanced x2
is there anybody that can help me ? which usb/is2 interface have to buy between Amanero , jlsound , diyinhk ? So, do you have also pcb with dsd filter and muting circuit ? and the output, better audio trasformer or else?
Please help me, thanks in advance
Best Regard
Emilio
Best Regard
Emilio
after to be was entire night to read this thread, maybe I have understood that I needed to build my nodac. So, the muting circuit and lp filter are an only circuit board, that has name Single-Ended.
But the flip-flop, isn't clear, It to use only for balanced output or is there another way?
My summary that I have need: the Jlsound with its isolator, then muting circuit and lp filter for only single ended output. But if I want to use also a buffer or gain, for example an output trasformer or tube buffer, I must to consider also another diy pcb (flip-flop or else)?
Caad: balanced x 2
torb: balanced x2
Dimdim: balanced x 1
Caad: balanced x 2
torb: balanced x2
Almost...
The single-ended board just provides a single-ended output, which you can feed into a suitable SE buffer if you wish. That's what I did with my initial build: JLSounds >> LP filter >> JG Buffer.
The flip-flop board provides a balanced differential output for use with transformers (as with Hazard500's build) or a buffer that accepts a balanced input. I'm close to completing a project that uses a flip-flop board to feed a Broskie BCF tube buffer.
Muting is needed in either scenario.
Hope that helps.
Ray
Caad: balanced x 2
torb: balanced x2
Leon77 : Balanced x 2, Single-Ended x 2
Caad: balanced x 2
torb: balanced x2
jborden: Balanced x 2
Caad: balanced x 2
torb: balanced x2
Almost...
Hope that helps.
Ray
This is very interesting, as I was going to use a BCF following the flip flop boards as well. Can you give any more details?
I may have missed it despite my reading this thread twice, what is the output voltage of the flip flop boards? Thanks for doing this work!
Please can someone link again to the calculation for cap and resistor values for the lp filter, it seems to be hiding from me..
I don't recall anything about a calculator here James. I have a copy of this software;
TCJ Filter Design - Download
I can do a calculation if you need.
Ray
Thanks Ray, I think it was a link to the formula for working it out rather than a calculator per se, but if you have a simple method that would be great
My amps have a 50k input impedance, but I guess if it's simple and you could work it out for 10k 50k and 100k others would likely find that useful.
Thanks,
James
Thanks,
James
- Digital Line Level
- The Best DAC is no DAC
