The Best DAC is no DAC
Hazard500: flip-flop x1
Supra: single-ended x1
Stijn001: flip-flop x1
dwjames: single-ended x1
ichiban: single-ended x1
PJotr25: flip-flop x1
Pegasus21: flip-flop x1
skrstic: flip-flop x1
Snicklefritzz: please specify type required
flowerpot: flip-flop x 1
Umarcus: balanced x 2
Giulio: flip-flop x 1
Caad: balanced x 2
randytsuch:balanced x 1
deanoUK balanced x 1 SE x 1
Vdi_nenna: single-ended X 2
merlin el mago: single-ended x 2
Nikola Krivorov: single ended Х1
pgour : Flip_Flop x 1 + SE x 1
ligascon: balanced x 1 SE x 1
matejS: single-ended x 1
analog_sa: balanced x 1 SE x 1
lukaluka: flip-flop x 1
xaled: single-ended x 3
Anjump123: Single-ended X 2
asanden: balanced x 1 + SE x 1
whmok: single-ended x 2
JimS: balanced X1, single-ended X2
flowerpot: flip-flop x 2
Caad: balanced x 2
Caad: balanced x 2
Guglielmope: balanced X1, single-ended X2
Caad: balanced x 2
iestynrw: balanced x1
I had a small packet arrive today...
...the first batch of the revised single-ended boards.
I'm aiming to make one of these up and test it over the coming weekend.
Also, the parts I'm waiting for to finish the flip-flop prototype are now on the way so I should be able to get that tested next week too.
Ray
Ray is possible to buy the B.O.M togheter the pcb?
Felipe
Ray is possible?
I've got a heavy cold so haven't felt like making as much progress as I had planned. I have managed to assemble one of the new SE boards but haven't installed it into my prototype project to test and audition it; hopefully in a day or so.
Felipe
I have been pondering the question of PCBs or kits. Everything needed to build one of these projects is easy to obtain and I don't really want to spend my time putting kits together so I think I'll just supply PCBs. I hope that isn't too much of a disappointment.
As you can see from the pictures, the PCBs are largely self documenting, with part numbers and values printed on the PCB wherever possible. I'm working on a separate BOM and some assembly notes for each of the boards.
Ray
Caad: balanced x 2
torb: balanced x2
Snicklefritzz: balanced x 1
Caad: balanced x 2
torb: balanced x2
is there anybody that can help me ? which usb/is2 interface have to buy between Amanero , jlsound , diyinhk ? So, do you have also pcb with dsd filter and muting circuit ? and the output, better audio trasformer or else?
Please help me, thanks in advance
Best Regard
Emilio
after to be was entire night to read this thread, maybe I have understood that I needed to build my nodac. So, the muting circuit and lp filter are an only circuit board, that has name Single-Ended.
But the flip-flop, isn't clear, It to use only for balanced output or is there another way?
My summary that I have need: the Jlsound with its isolator, then muting circuit and lp filter for only single ended output. But if I want to use also a buffer or gain, for example an output trasformer or tube buffer, I must to consider also another diy pcb (flip-flop or else)?
Caad: balanced x 2
torb: balanced x2
Dimdim: balanced x 1
Almost...
The single-ended board just provides a single-ended output, which you can feed into a suitable SE buffer if you wish. That's what I did with my initial build: JLSounds >> LP filter >> JG Buffer.
The flip-flop board provides a balanced differential output for use with transformers (as with Hazard500's build) or a buffer that accepts a balanced input. I'm close to completing a project that uses a flip-flop board to feed a Broskie BCF tube buffer.
Muting is needed in either scenario.
Hope that helps.
Ray
Caad: balanced x 2
torb: balanced x2
Leon77 : Balanced x 2, Single-Ended x 2
Caad: balanced x 2
torb: balanced x2
jborden: Balanced x 2
Almost...
Hope that helps.
Ray
This is very interesting, as I was going to use a BCF following the flip flop boards as well. Can you give any more details?
I may have missed it despite my reading this thread twice, what is the output voltage of the flip flop boards? Thanks for doing this work!
Thanks Ray, I think it was a link to the formula for working it out rather than a calculator per se, but if you have a simple method that would be great 🙂
My amps have a 50k input impedance, but I guess if it's simple and you could work it out for 10k 50k and 100k others would likely find that useful.
Thanks,
James
