The Alpha Big Boy with Buttah (ABBB) 52w Class A Amp GB
I'm imagining a pair of long, slim monoblocks with the heat sinks sticking up in the rear. The many design aesthetics have me reaching for the sketchbook. That's nice looking work Vunce!
gary s - 2 boards
jwjarch - 2 boards
Vunce - 2 boards
meanie - 2 boards
shattered_dream - 2 boards
yoaudio - 2 boards
md_Stryker - 2 boards
Roundtoit - 2 boards
I don’t think it’s a problem to show you guys what I am going to be making on a P2P veroboard to test out a new SSR speaker protection/delay system that Jhofland designed. It’s very clever and compact. It uses an optoisolator to sense the DC and several comparators to decide if the level warrants disconnecting the speakers. The second comparator checks a time constant to give enough time for the turn on thump to settle. These comparators then drive another optoisolator to drive the gates of a pair of low RDSon MOSFETs (the Solid State Relays) that make/break the connection to the speaker. All will be powered from the positive rail via a 27v zener diode voltage reducer.
attachment.php
Hehe, I forgot that I have a liquid cooling setup somewhere waiting for me in a box. However, I recently acquired a pair of very nice Mac Pro workstation CPU coolers that might be perfect for the job.
The liquid cooling does keep things compact. Still needs a fan though. So Noctua will still be the one to use.
Efficient way of doing things though, with 6 guys around the world all doing and concentrating on different parts of the overall design. That would also help with checking updates and new features as you are adding right now to this new design well done to all, I know you are in DC and Hugh is in Melbourne and JPS in Germany, so to the other guys a big thanks all round.
These look too good to pass up. Thanks for all the work you you guys are putting into this project. Added to the list hope it’s OK.
Evan
gary s - 2 boards
jwjarch - 2 boards
Vince - 2 boards
meanie - 2 boards
yoaudio - 2 boards
sst4270 - 2 boards
chilly - 2 boards
Kokanee - 2 boards
evanc - 2 boards
added myself on the list for 2 boards. thanks for all the hard work guys!
gary s - 2 boards
jwjarch - 2 boards
Vince - 2 boards
meanie - 2 boards
yoaudio - 2 boards
sst4270 - 2 boards
chilly - 2 boards
Kokanee - 2 boards
evanc - 2 boards
a3cervo - 2 boards
2 boards for me too. Thanks!
gary s - 2 boards
jwjarch - 2 boards
Vince - 2 boards
meanie - 2 boards
yoaudio - 2 boards
sst4270 - 2 boards
chilly - 2 boards
Kokanee - 2 boards
evanc - 2 boards
a3cervo - 2 boards
markus22ch - 2 boards
