The Aleph-X
jh6you said:
The 0% current gain (i.e. constant current source) means that the current source delivers no current at idle…?!?!
0% gain on the current source means constant current
from the current source at the bias level. The AC value
of this current will be 0 since it doesn't change.
Let's say you bias the current source at 1 amp. If the
current gain is 50% in an Aleph circuit, then the current
through the source will vary from 1 amp at idle to 2 A
at maximum positive output current to 0 A at maximum
negative output current.
If the gain is 0, then the current is always 1 amp
if the gain is .9, then the current is +10 A at maximum
positive and 0 at maximum negative output current.
Aleph-X unbalanced?
Dear all,
I am in the difficult position upon to decide on which will be my next amp. After 3 years with my beloved aleph3 clone mated with my Tannoy HPDs, I am about to built an aleph2 or an aleph X. My target requirement is about 60W on my 6,5 ohm loudspeakers.
So, I wanted to ask if I use my aleph L clone for preamp is it better to build an aleph2 or X? To my eyes an x would be valid only if my cd player and pre was balanced. Is this a correct assumption, or an X is working equaly well with unbalanced sources as an aleph2 does? To my eyes it seems tha driving an X with unbalanced sources I only get to work half the circuit, while in an aleph2 I do not.
Any help would be greately appreciated.
Sincerely,
Panos:scratch:
Audionut,
I'll make up something tonight. You should be aware that there is a whole lot of freedom of choice considering the overall number of components. I experimented only with a limited number of variations, other people have done more tweaking and came up with very different sound impressions. Some of these tweaking include different CS, different feedback and input resistor values.
By far the most important thing is that you should get some Mills resistors from the bulk purchase thread I started, just kidding. 😉
r36 and r38 from aleph-xj
r36 and r38 are the famous Ian MacMillan resistors.
These help to control the absolute offset. This is the
offset from one output to ground. The differential offset
(offset between + and - output) is not affected by these.
rtirion,
how much gain did you calculate for your frontend, don´t you think it would need V instead of BL Sjs?
alternative
Idss classification V type would be better if I would be able to get
them. V type would mean little higher transconductance, and
more feedback, so little lower distortion. For this to work you
would need to bias the frontend harder (let us say 15mA per
side of the diff pair), hence this would mean at least two V(iolets)
in parallel to deal with the increased dissipation. The current
source for the frontend would need to deliver more current,
means more dissipation, so a different type would be needed as
well. I remember Mr. Dieckmann recommending a 2sj77.
Your schematic shows 2SK109G. Did you mean 2SJ109GR?
These would be the lowest Idss class.
The 1k drain resistors R23R and R25R in your schematic suggest
a bias of only 4 to 5mA. Good for GR type, not so good for V type.
