Test LP group buy
Pano: Interesting point. From one view this is one of the first (depending on how you view adjust+) test records designed to work in conjunction with a PC then we need some markers to potentially allow code to know where it is, but do we need the added voice over?
I always have a hard time figuring out where the crossover test signal are and an even harder remembering which was the left and which the right channel track. So if space needs to be filled I either want an hyptnotic track that helps my brain with braining or a bit of extra spacing between tracks.
Thanks, for those!
  1. 3150Hz Speed, wow+flutter
  2. 1kHz Reference level 5cm/sec, distortion, phase
  3. Left identification
  4. Right identification
  5. Signal in phase
  6. Signal out of phase
  7. Pink Noise (level?)
  8. White noise (level?)
  9. Full range sweep @5cm/sec - FR and EQ As extended FR as possible.
  10. same 24dB below reference
  11. same 18dB below reference
  12. same 12dB below reference
  13. same 6dB below reference
  14. same @ reference
  15. same 6dB above reference
  16. same 12dB above reference (if possible)
  17. Rotating phase
  18. L+R
  19. L-R
  20. Crosstalk test
  21. Silent Groove for Rumble (maybe locked)
  22. Low frequency sweep for cart & arm resonance
Thanks, for those!
  5. Signal in phase
  6. Signal out of pahse
  17. Rotating phase
  18. L+R
  19. L-R
  20. Crosstalk test
Looking good!
If we have space, I would like to add square wave test and tone burst tests.
Hi Pano,
Consider giving a few tracks as much time as you can to fill any unused space. I can see the W&F test (3150 Hz) and the crosstalk test needing long play back times for running tests. Same for the rumble track.
Trackability - was said not to be needed
LF Stabilty - see low freq sweep
I really can't see a serious need for those either.
VTA -What you got?
Azimuth - what you got? Want them at a specific radius?
I'd really wonder about this as well. However these might make a suite of tests for LP number 2. Basically signals used to set systems up where LP number 1 would be more for technical testing of the equipment. There are some W&F tests where you have to wait longer for the system to act up. Consider putting the W&F and speed tests in the first couple tracks since the effects would be amplified by being in those first tracks. A speed test track near the beginning and another nearer the centre would show how much the table is affected by drag forces from the stylus. One would hope there would be zero difference.
I'm not sure that spoken announcements would be that useful. We can read the liner notes and count the tracks. At the most, maybe a computer voice indicating track number would be sufficient.
I can't see any stylus tracking a square wave cut into the record. It would be pointless to do this. Tone bursts have similar issues. You are dealing with a mechanical system that has mass (inertia) concentrated in a really hard substance (the diamond tip) vs. soft vinyl. Any bets who the winner in that contest is going to be? One ex-record track the first time you play it.
-Chris
