TDA7294 + Power Transistors AMP (TDA7293 to come also)
http://cxem.net/sound/dinamics/dinamic92.php
http://cxem.net/sound/amps/amp138.php
  • 2-pcb-tda-toshiba.zip
Bridge can be found on page 9 of this thread where I posted the PCB layout. The key is to take the output from one module and via 22k resistor put it to pin 2 (inverted input) of the TDA in other module, also connect the pin 3 (non-inverting input) to the ground and that's all !
No need for additional op-amps, you just use the one found within the input stage of the TDA chip.
This is tested and works! Enjoy :p
gev - nice one, even mosfet version :)
TDA7294 bridge (same on 93)
NOTE: quick google find and just schematic without transistors
kebbz can you post your schematic, if i find the time ill get on the job on editing post #1 to refer to your posts to get some system in this thread
Hi dr frost,
I am building your design using tda 7253 and original toshiba transistors. i am not sure on how to determine the output of this circuit while using 25-0-25 @3 ampere current EI core CT transformer... i.e 150VA i am going to use it to drive subwoofers. but i am somewhat confused, i have 2x 4ohm 100w rms subwoofers. if i use the transformer, will it be able to deliver peak power of 100w into those 10 inchers in both? or should i drop the plan and use only one 4 ohm sub ? else, what is the power i can expect into 4ohm(single) 8ohm(series) loads and 2 ohm(paralell) loads with the given supply?
Hello dr frost & all diyers
I still lay about amplifiers. and I am so excited to make this amplifier. I plan to make dual mono. This layout I would use. Please be corrected.
if any body have schematic opamp stereo/bridge with selector mode, please share .
I want to pair it with this amplifier.
Sorry if my English to bad.
martin martinez in theory it should work with everything from OP-AMPS to any old-new home Amplifier, you just need the feedback (22K ohm in this case) and the "sync" resistor needs to be configured.
sameer x1 & koming looks good with the PCB, any plans to sell them?, my "hole print" thing works but it is easier to have a nice board with a good layout.
EDIT: andrewlebon THAT's quite an AMP!!!!, can't see if it is a stereo or just a bridged mono HIGH powered AMP
EDIT: It looks to be bridged so that AMP will push peak watts in excess of 2500W in 2 OHM!!!!
