TAS1020B-based Asynchronous USB to I2S/SPDIF converter 24bit/96kHz
New Production want to buy List :
guglielmope x1 - I2S - Italy (with galvanic isolation and external oscillators)
korben69 x1 - I2S - France
Ryssen - x1 - Spdif - Sweden (external oscillators)
And I wonder,on the DC jack is the possitive in the middle?
center pin is almost always positive
qusp x 1 I2S - Australia (with external oscillators)
Hi JarekC,
Can i confirm that the usb to i2s converter works with Linux ?
The ADUM usb isolator also works with Linux ?
what the cost for both units and postage to malaysia?
thanks
kp93300
AD1. Converter works with LINUX.
It uses native driver for UAB Audio Class 1.0
AD2.
I have not tested this, but should be OK.
ADUM is transparent for USB signals.
AD3.
Shipping to any country is about 6$
Best regards
JarekC
I am asking for more info on these 2 items
I quote
Options cost:
-external oscillators + (additional parts) 25$
-galvanic isolation module 18$
Unquote
Do you mean external oscillators with extrapower supply and the clock signal piped to the board via a wire? I have the Kwak clock and can i use this .? What clock frequencies works with the usb to i2s board ? I have a few oscillators left over from a previous project.
Is the galvanic isolation module equivalent to the digital pulse transformer for spdif output ?
thanks
kp93300
I quote
Options cost:
Unquote
thanks
kp93300
Ad1.
No.
Oscillators (22.5792MHz & 24.5760MHz) + Multiplexer LCX157 + LDO +RC parts are mounted on PCB.
If you would like use Kwak clock you need 2 frequencies 22,5792MHZ and 24,5760MHz. Signals levels are 3.3V.
Ad2.
No.
Digital pulse transformer make isolation on SPDIF side.
Module (ADUM3160) make isolation on USB side.
JarekC
SPWONG x1 - I2S - Hong Kong (with galvanic isolation and external oscillators)
Thanks for your works!
Hello,
I'm also interested in this, SPDIF version, but have no great experience with diy. Is there a list somewhere of the steps needed to have it up and running?
Thanks,
Gio
Converter is ready to use.
For all systems Windows , Mac Os, Linux it uses native drivers.
So you connect converter to PC and it should be recognized automatically.
In system it will appear as "Audio device"/"USB->SPDIF V1.0x"
Sorry but at this moment SPDIF version is sold out.
New PCB version soon.
JarekC
Hi all,
New PCB for USB-I2S version is READY.🙂
Yesterday I sent files to PCB factory, so test pices should be on my desk for 10 days.
Connectors on PCB:
USB - USB bus (type B)
I2S - I2S bus (IDC 2x5pins raster 2.54mm)
POWER - input for external power supply (2x1 pin raster 2.54mm)
JP3 - jumper for selecting USB Bus/External supply, instead jumper you can connect switch(3x1 pin rasetr 1.27mm)
LED - Power LED and Fs LEDs (each Fs has own LED) (6x1pin raster 1.27mm)
J3 -input for external master clock (4x1 pin raster 2.54mm)
Changes compared to the previous version:
-galvanic isolation on PCB (ADUM3160 + LDO)
-shorter track for Master Clock signal (from Xo to TAS1020B)
-elimination of the multiplexer in the Master Clock signal path
-sampling rate signaling with 4 LEDs (each has its own LED)
-series termination resistors on the I2S bus lines
-22.5792/24.5760MHz generators + LDO can be mounted on the PCB, or connected via J3 connector
-additional 16-bit modes for connecting 16-bit DACs such as TDA1541A, TDA1543, etc. (during testing)
-AC-3 passing through mode (during testing)
-derived power to the I2S connector, ability to supply DAC
-smaller dimensions, only 67mm x 30mm
-4 mounting holes
Best regards
JarekC
