Taramps HD3000 V2 in protect mode
It actually is in the same location as the schematic indicates. At least this particular schematic I downloaded. I measured one of the others and came up with almost 100 nF before I came across a schematic.
You can start by probing pins 2&4 of the 4427. If you dont have signal there, you have a faulty mcu.
Then you can check pin 6 of the 4427, you should have 12V there.
If you have the above and no output on pins 5 & 7 of the 4427, yes replace the gate driver.
I would like to post the correct frequency, it should be 25KHz, not 20KHz as i wrote earlier.
If you have drive signal to the fets but overheat, then there is not enough current drive and you should use the original part.
