Taramps DS 1200X4 turns on but sounds distorted
The IC has UVLO which will shut it down if the voltage on those points drops too far. Initially, the voltage is supplied by resistors from the positive rail but after oscillation starts, it's supplied by the low-side VCC2 supply. It shouldn't drop (measured directly across the #25 points) very far below the voltage across the COM and VCC2 terminals.
It's quicker with my finger lol! A quick touch and I can tell if the there's audio.
So C44 and the one next to it and C83 have very high ESR. I've changed those caps on channels 1-2 and they sound normal playing music, I'm in the process of changing channels 3-4 but the donor board I have is all out.
It seems like those 4 caps were the issue, I changed them all out and now the amp is playing.
I can't test it yet and give a scope reading because it's still pretty early at my house.
I will send it to in a few hrs. These are some photos of what I did, I apologize about how it looks but it was the best I could do given the fact that the IC traces were ruined and I don't have anymore surface caps because the donor board is all out.
Low side and high side gate drive...
I see, one was way higher than it's value but the ESR was 11 ohms, the others were their value but the ESR was also 11 ohms.
