Entas,
If you want to use two drivers, you will need to double the CSA, but keep the same height.
Put the center between the two drivers at the same place you would put the center of one driver.
What does the CSA stand for? Thanks for the answer!https://www.diyaudio.com/forums/full-range/88787-tabaq-tl-tang-band-post6118643.html
cross sectional area.
So, the original TABAQ being 10 X 12.8 cm (internal dimensions) has a CSA of 128 cm2.
For two drivers, you'll need to double the CSA, so 256 cm2. Same thing goes for the vent.
But you need to keep the length of the line the same.
I have posted my .hornresp file in the previous post. As you said it has 256 cm2 CSA and 32cm2 CSA vent at 7 cm lenght.
Quarantine days here in Norway, I have 2weeks to use on whatever I want!
So I've decided to build two tabaqs one with the W4-1320, 30mm oak sides and birch laminated MDF frontbaffle.
The second build is with the 3" spx-32m in plywood.
But can someone help me with simulations for this driver? I also need to find out how much stuffing to use.
Good things to do while stuck at home! 🙂
For the Monacor, if I trust HornResp, I would widen and shorten the vent to make it a bit more flatter in the low end.
You will lose some Hertz down low, but it should be better balanced.
Going to 24 cm2 and 7cm long will adjust the low end better, as you can see in the pictures.
As for stuffing, I'd stay the same.
Thanks! I just tested the monacor spx-32m in the TL (updated version) and it sounds very good, I wish I could analyze it with a mic and see some numbers.Good things to do while stuck at home! 🙂
Is it possible to use a videomic? I have a Røde microphone.
if you have a calibration file to make sure the Rode you have can measure flat, then sure.
If not, and you want to pursue DIY audio, a mic is an indispensable tool
Hi Simenms
The volume should be increased: Cross section should be 154 cm2 and the port should be 17 cm2. All lengths are the same. Stuffing 63 to 112 gram. This is based on TB W4-1052SDF with Fs of 75 Hz and Qts 0.36.
Hi
Bjørn
Hi
Bjørn
Thanks! Do the W4-1052SDF and the w4-1320sd have the same specs?Hi Simenms
Hi
Bjørn
The first Tabaq build attempt dramatically showed up the limits of my "El Noobo" woodworking skills. I'm about to start again but the nowadays the only MDF sheets available thickness are 14mm. & 18mm.'s.
I came up with the idea of building the whole cabinet with 14mm. MDF but the front baffle with 18mm. MDF
Keeping the inner size and volume the same as project spec's, does the front baffle different thickness somehow affect the project ?
Should be even better. The important thing is to keep internal dimensions the same.
I'm in quarantine for two weeks! Both speakers are done now.. the first testing I did was on a Rotel RA-11 amp that sounded ok but not quite as good as I wanted..You're quite fast!
Moved them to a smaller room and with the TPA3116D2 amp they really came alive, I was really blown away by the dynamics and detail.. and I did not expect this much bass from a small driver..
I got these two drivers for 35$ for the pair so just had to try them.. now I can't wait to listen to the w4-1320 in my next build..
Do you have a suggestion for a low cost tabaq driver?
I have access to Monacor dealership prices but looks like people don't believe in those drivers because of the high FS.
The spx32-m did really suprise me! It I'm no expert..
Still quite fast! did the glue have time to dry! 🙂
The spx32-m seems like the best from Monacor... I remember looking at other drivers from them, and most had ragged FR curves.
If you can order from places like Aliexpress, here are the two drivers I have used that sounded pretty good, after adding a small notch around 5 or 8kHz.
The best one is the beige paper cone. Amazing bass in the TABAQ, yet refined enough up in the higher frequencies.
The black cone and red whizzer was cheaper, but also a good performer, not as clean as the beige, but still good enough to amaze a friend who begged me to give them to him.
He put them in his restaurant that plays classic rock all day long.
That beige one says MarKAudio&CHP75. You can get MA drivers on AliExpress? Or is that a knock off trying to do a similar name but added the & and made it one long word?
Edit: must be a fake as there is no Mark Audio CHP75 model to be seen officially.
- Full Range
- TABAQ TL for Tangband
