SYMEF amplifier
So that this thread won´t die..
How to make the parts fit in the crappy cabinet?
More progress of my SYMEF
Got some free time during this weekend, so resumed my build again. The difficult part is drilling, tapping and finally aligning the transistors and bending them carefully so they are same height.
I've spent several hours on this. While tightening screw on one of the power transistor the screw head came off. Made a failed attempt to remove the leftover part, don't have patience to drill new set of holes. Luckily I had a L shaped object that I've used to keep the other transistor in contact with the heatsink.
Fired up and measured all the voltages, they seems fine and the offset is only 2mv. Need to setup the bias, what is the recommended value of the output current for these transistors? May be I'll test with real speakers next week.
Very nice.🙂 Try keep the output wire away from the input. Ensure that the transistor where the screw head came off has enough contact with the heat sink.Its failure could lead to a cascade. Set bias by having 23mV across R14. Cheers.:cheers:
Thank you Mr. Harrison, I've set the bias as you suggested. Amplifier build is finally complete over this weekend, ofcourse need a very good case to justify its performance. There is no hint of any oscillation, bias is quite stable, and vbe multiplier is quite responsive to heatsink temperature. Probably need to adjust the bias after it reached steady state.
Measured 1khz and 10khz square wave and 10khz sinewave response, its clean and rounded edges on square waves.
Played through my home made bookshelf speakers. In one word, the sound is marvelous. Although I have to do an extensive listening the amp just displays its character in the first song itself. Sound stage is huge, vocals are accurate and highs are detailed. Overall the sound is very balanced in the whole audio range, no slamming bass or shrill voice. Its just perfect, you don't want to stop listening.
I am not comparing this amp in isolation. I've already built SymAsym, and F5 also I have couple Luxman amps, so I have some very good amps for reference. Being said that, this is a very good sounding amp with huge soundstage and openness.
Hello Mr. Harrison, I don't know what is your magic formula is, but it is wonderful. I cannot stop listening to this amp. To justify its sound, I'll get a very nice case with bigger heatsink and route the wires cleanly.
Bambadoo, what are you waiting on? Complete the amp you'll be greatly rewarded.
Hi Harrison/Routhun,
the test I am proposing is not to show up anything bad in the amplifier, I would not do that. What I am suspecting is that the low frequency strain on the power supply would be exactly what is being discussed in the reservoir capacitor thread and what looks like 20 000uF/rail on the photo.
The only reason I asked for the test is that it seemed that routhun was already set-up to do another test. If you have already closed up routhun then do not bother, we will catch someone else who may be about to test an amp.
Hi Nico,
Power supply reservoir capacitors are 18000uf,50v panasonics. The total capacitance in this amp is 72000uf for both the channels. I am measuring the waveforms with 8 ohms pure resistive load connected to the output. Any case I'll measure and upload the results soon.
Thanks,
Hi Nico,
Thanks,
Hi Routhun,
It will definitely be interesting to see the output waveform with so much capacitance per rail.
Would maybe support Gootee's forecast that under power supply stress conditions there may not be enough time to recharge the capacitors. Besides it would be of as much interest to your fellow SYMEF constructors. Thanks for participating Routhun.
Sorry for highjacking your thread Harrison.
SYMEF measurements
Hi Nico,
Here is the square response of SYMEF at 20hz, 100hz, 10khz and 20khz into 8ohms pure resistive load.
Thank you very much Routhun. I trust that you found this low frequency response both unexpected and puzzling. However, your scope is on AC coupled please use DC coupled else the effect is accentuated by the probes high pass filter. I would like to see your power supply's effect on the low frequency.
SYMEF measurements with DC mode
Hi Nico,
Thank you for correcting me it was my mistake, I was using the AC input mode thats why square wave response is not great at lower frequencies. Now I measured again with DC input mode, now the response looks much better.
Thanks,
