PauloPT, regulate everything short of the output devices, it is unnecessary to regulate the output devices.
That was my first though too. But how do I separate everything else from the outputs? Can I just disconnect the tracks and use a separate supply?PauloPT, regulate everything short of the output devices, it is unnecessary to regulate the output devices.
Thank you.
hi paul..
first if you have a cd player or dvd you can use it because it sounds better.I have noticed it when playing music specially when it comes to chorus the sound get compressed or the amplitude has limitation when using computer eventhough you have soundcard.
about board I have come up with a new layout and tomorrow I will upload it.I have tried the jurassic style,in terms of THD it is superior than straight lines.
regards,
joel
regards,
joel
Hi Harrison,
Regulating the VAS and input would be sooo nice! I don't have the skills (yet) to design such a modification, but you have. Can you think about it please! 😉 But don't change the sonics of the amp, I'm too in love with it!
Hi Joel,
Ok, I won't 😉Dont do it
Hi Joel,
I have a DVD player. But it's so pratical to have all the music in the hard drive and use your favourite media player...😉 You're right, it sounds better with the DVD player 🙂first if you have a cd player or dvd you can use it because it sounds better.
Then lets go with round lines 🙂I have tried the jurassic style,in terms of THD it is superior than straight lines.
Hi Harrison,
Hi Joel,
Gold over blue, many thanks! 😎Heres something for you to investigate
Hi Joel,
Good work! 🙂This is what I have come up yesterday
Harrison,
is it possible to use the same transformer feeding two separate supplies, one regulated for the regulated section and other unregulated for the outputs?
And how much current the regulated section needs?
Thanks!
Thanks!
Hi Paul,
Nicos', estimate should do 😉 . Do you have a separate winding on the same transformer? If not use another transformer.
kind regards,
Harrison.
kind regards,
Harrison.
Check this...
Hi Harrison,
Is it ok?its not yet final.
regards,
joel
Hi Harrison,
regards,
joel
I've been experimenting with input and VAS regulation with LM317/337 chips but I seem to prefer full amp regulation. I added a 15000uF of caps after the LT1083 the bass in good, also the dynamics are impressive. I don't know if adding this much capacitance after the chip will negate the ideia of regulation in the first place...😕
Anyway, does a single LT1083 per rail (Imax = 7.5A) be enough for the SYMEF?
I don't know if Joel could find away to put this regulators in the same pcb as the main amp... Just an ideia.😉
Hi Paul,
Create a stereo amplifier of the SYMEF that you will keep constant and not modify. It will be for your listening pleasure and also for reference. You can use it for AB comparisons with the modified versions.
You may choose to use the latest PCB we are just about to roll out.
kind regards,
Harrison.
kind regards,
Harrison.
- SYMEF amplifier
