Symasym 5.3 "AAK model" builder's thread
SheldonD,
To answer your questions.
1.I see little reason to keep 2 diodes in circuit
Don't populate D2 and D4 as shown in the PS schematic below.
2. there should be some decoupling capacitors although Ii think 4x4700 is huge overkill. It may be my suggested 2 x 1500ufd might not be enough.
If your external PS has plenty of reservoir capacitance, rule of thumb being 1000uF for every 10 watts of amplifier output power, then your choice of 2x1500uF is fine.
3. 0R2 resistors as input to decoupling caps would also aid in decoupling. so I would leave these in.
Just make sure the 0.2 resistor is rated for at least 3 watts.
Al
Here's the schematic.
difficult to find some parts at a good price...
diodes hfa are 6$/p . (4,75€) here.
Can i use this ones from ST "Turbo 2 ultrafast hight voltage rectifier ST Microeletronics STTH12R06D/FP.
12A 600V 45ns in TO220AC (find in RS catalogue, in stock) price:1.5$/p
About 2n5551, are finally BC550C better ?
Thanks.
jf
Component change advice needed
Guys,
I'm using MPSA18 for the input pair and MPSA42/92 for all other small signal device. Is that OK?
Can I use Wima FKP2 (polypropylene) for C2 and C7 instead of Silver mica?
Driver and output stage are MJE15034/5 and MJL4302/3281. Is that OK?
Power supply from 37ac (150VA) EI transformer producing around +/-50V driving two channels.
Pls advice.
Thanks.
Final schematics using MJL4302a/MJL4281A
I've received boards from Ryssen and parts from mouser. Just wondering what is the final schematics using the above transistors with +/-50V dc power supply. It would be a great help for the fellow members if someone can publish the circuits using different output combinations for this PCB. I know the differences were posted in various threads but it would be handy if some one can consolidate those things and post in a single PDF file.
thanks,
routhun
Re: Component change advice needed
Ipanema said:
Guys,
Pls advice.
Thanks.
Hi, with +/-50v you must not use mpsa18, it has 45v rating. You can use mpsa42.
The Wima fkp2 are fine.
Outputdevices are fine, but, at +/-50v a single output pair becomes critical even when driving only 8ohms.
Symasym was designed for +/-36v, +/-40v at most.
MJL21193 said:
It has some similarity to the symasym. Here it is:
:clown: yes, it's also a ClassAB amp!
But, you can not use 2n5550 for q14, it will overheat. BD140 for q4 is also not suitable, BD140 has max rating of 80v.
Without vas-protection, q13 will blow on excessive positive clipping...
You should consider basestoppers to the drivers, what is c7 for?
R2 should be directly behind c5, otherwise your input filter operation depends on output impedance of signal source.
Q3 will also overheat, so will Q1/2, are you sure you want to feed ~40ma into the input diffamp?
Why are r7/26 different?
Mike
MikeB,
Thanks for your advise. Is there anything wrong with my power supply? 37ac-0-37ac ==>rectifier==> +50V/-50V
which one will sound nicer? Silver mica or Polyproplene?
My batch of MPSA42 only have hfe of 100. Is that good enough? While my MPSA18 have hfe of 700. Which one will sound nicer in your opinion? I wouldn't mind to lower the power supply if it helps. 🙂
All the the pair transistor are hfe match but vbe is unmatch.
Thanks.
