SX-Amp and NX-Amp
correct image
I will post the correct image below
The latest NX amplifier document is 2.09, November 2014. In cases where the schematic and BOM list different values for components, the BOM is usually more up to date.
I had downloaded the latest pdf from Bonzai's site, I already had an older pdf from a previous download.
That is where I came unstuck.
The PSU+Prot sch is not legible and the attached BoMs have anomalies, so I asked some questions.
It appears the Rb1 and R2 have been omitted from the sch and from the PCB.
Have a look at post #871.
There was a reason Bonsai changed U1 to PDTA144ET
except that the higher resistor value does not solve the potential overvoltage issue. That is mentioned in later posts.
For some reason the better solution of the added Rb1 was not put into the sch nor into the PCB. But it's an easy fix for those that keep a stock of 603 or 805 resistors.
Instead of 27k4, I had 22k and that gets the voltages and the currents down to very acceptable values even for a +-50Vdc supply.
One could even use a 1/4W 805 10k. With the lowest transistor resistor of ~8k the worst case current would be 51V/{10k+8k} = 2.83mA.
The two dissipations become 80mW & 64mW.
If one were using a 1/8W then Rb1 could be 18k for a worst case dissipation of 69mW (55.4% of rating).
I really just wanted to get you to that part of the discussion so you could see how things developed. I knew you would understand what was going on better than I could explain. I have the original boards so I had to cut in the resistors. Back then I didn't keep any SMD parts in stock so I used through hole resistors as can be seen in some of the pics I posted. I haven't seen the V2 boards.
Rb1 is something I added but Bonsai preferred to change U1 to PDTA144ET. The PC board was not changed to add Rb1 as you noted.
In the 2.09 document R2 is gone from the PC board and schematic but it remains in the BOM. I don't recall any mention of why it was removed but it doesn't appear to be critical either way.
That is where...
Andrew,
I'm glad to see you were finally able to get the PCB's and that you are building this amp. You've contributed greatly to DIY Audio over the years so I'm interested in your take on building and listening to this design.
I've been reading about several amp designs here since around 2008, i.e. DX Blame, various Apex, Nagy's Goldmund clone, Roender's FC-100, various Lazycat SSA's, Honeybadger, not to mention Pass designs like the F5 turbo. I chose the NX amp for a number of reasons:
1. Direct coupled and decent offset without a servo circuit.
2. Relatively low parts count and pretty much symmetrical schematic.
3. CFA design with wide bandwidth.
4. No "unobtanium" parts and PCB's available.
5. Excellent single .pdf document with everything in one place, so no need to sift through 1000's of forum pages to get all the key info.
The last 2 items are what really sealed the deal for me.
Bonsai, Thanks for all your work on this and for sharing!
