Sure Electronics Tripath boards?
Another armored design, very impressive.
How did you get the top edge to fit so snug? Mitered edge?
Did you buy the plates pre-cut or can you do that yourself?
As for the leads from the tank caps: common wisdom is to keep them short to avoid forming an oscillator from capacitance and inductance. You could at least twist them, I think.
Arjen Wrote:
I would like to have some feedback on what you guy's would like to see.
In my humble opinion the existing design is pretty good Arjen, however some small changes I would sugest:
As you say, thicker copper and/or some of the rails a bit wider .
Perhaps a bit more room on board for the input caps & enough room for at least 2x 2200uF "tank Cap's"in place of the existing 220uF's.
DC offset trimming on board.
Better quality / tolerance SMD's.
Certainly happy with my Mk1 version though & listening to it now fed by a DAC / Headphone amp I have just completed. Sounds Sweet..
Thanks! I will twist the wires. The plates is not miltered they just "come together" when belt sanding them. Cutting the plates is done by a regular buzz saw. Alu is not that hard so many regular wood tools will do.
Thanks paul,
I think if i need to get these things made, i better do it good, if not best for the money i spend on it,
i dont want to make things overly complicated, no need and it dosnt help for design quality either is my idea,
but im open for suggestions, and have started a new thread
i invite all people that use the TA2024 to give me some comments so that we can end up with a better product.
Hi Paul,
Could you please,show me the inside of Headphone amp that u had completed it. I would like to make one like you :angel: Please Please^^
Thank U..i'm waiting to see them
No credit to me, & no time to take photos at present. Refer Perco's post No 569 some weeks back. I was given one of these boards some time ago, not working.
After reading Perco's post, I simply repaired it & put it into a small case which matches my amp. I slightly re-aranged things (output caps), & fitted a 6.5mm headphone socket & switched RCA's for output.
It makes an incredible diference when using my laptop as source.
Will take some photos when time permit's.
Paul
Varisign
Herewith Photo.
The other option is to place a buffer inbetween. I have Pedja rogic discrete buffers that I intend to use with mine.
I'll report when I get a chance to check out the sound. I'm still doing the other modifications to the amps. I am documenting any mods on the web.
I'll update with the differences made by the buffers in the nest week or two.
ta 2024
hi blair
great website,i think you are right about the capacitors on these boards,300uf a side should be enough.IMHO they are assymetricallly wired so to speak,see pic.
ps nb this mod effectiveley removes supply protection diode
Re: ta 2024
hi albin,
pretty interesting mod there..
any significant gains in the sonic department?
thanks. have a nice day.
ps.
this is my very first posting in diyaudio. 😀
great discussion guys!
albin said:
hi blair
