Super V/i converted (LL1684 )
Hello Ganghao, I paid 2 months ago and I see nothing coming, no answer from your side to two mails and no tracking number. Is this normal? Thanks
Hi Myfavoritething,
I waited USB from the manufacturer, today I sent goods to you.
Your tracking number is: RR 120 376 102 VN
You can check under the link: B?u ?i?n Vi?t Nam - VNPost.
I'm sorry for letting you wait too long.
Thank for your wait!
Quanghao.
LL1570xl
I want to use the ll1570xl do I need the 10K resistor or not?
Hello Guanghao, I received my packet in good shape. A few remarks.
Neither 3 nf caps nor jumper or P2 socket are supplied... What did you advice for 3 nf? Which is the reference for P 4 connector?
Another thing Oscon are smd type. Does the purple mark is plus or minus?
Last thing for Amareno mounting, I think I have jumpers position on the main board of the DAC to modify, which are these jumpers?
hi!
no use this Cap 3nf,
Os-con purple mark is -
oh, you can use other , so i wil sen to you other !
it is ok ??
quanghao
Hello Ganghao I have now the jumpers for RCA/Cinch and ground, OK for OsCon, but I still need a pair of connector P4 with 3 wires to connect the passive output boards to both channels of main board. So yes, please send me 2 sets.
Two more points: which jumper to move to supply Amareno board and which jumper to move to suppress I/V conversion when using passive output boards? Could you send me a jpg (or a link going to these jpg) for both (if useful).
Thanks in advance
Hello Ganghao, I tried to change LNV of coax and AES BU. But it was too difficult and I fried boards both side and both inputs are dead. Optical is working. What will be the price for a new DAC board, working fully, without any modification to be done by the user...
