Hi
my last project is an hybrid with 2SA1215 and 2SC2922
drived from a copule of comlementary hexfets IRFP240/9240
(after evaluation will be IRFD110 & C)
the output is with big capacitors (20.000uF) just to leave DC
(this balanced solution don't create emphasys on music)
in this particular design i have put two bipolar devices instead
single one (in AB bias) because need Class A sound without bridge
there is an "auto-biasing" between a copule of complementary
transistor in this configuration, so need just a resistor base to base
Stee said:Hi
I can guess how it works
but could you send exact schematic?
Tripolar PNPN configuration
I don't know if works
is a project until this WE
this double bipolar ( renamed Tripolar ) is a PNP+NPN
with common collector
so is like a self-biasing device
that works (may be) in phase
as a variable resistor ( signal modulate value )
input satage with common source
split phase in two opposite rail
without feedback and mirror
may be works
thanks Eva
i have apply the same method in my loudspeakers
named push-push
same complementary copule working in-Phase
and pump so good...
plus an attractive logo now:
http://www.esafono.it/tauroamp.jpg
thanks Eva
named push-push
and pump so good...
Re: seriously save yourself
Have you floated this idea on other forums??
Andy
EDIT : My apologies to the language purists. I know the plural of 'forum' is 'fora' but many do not.
darkfenriz said:Great logo!
It's high time for a group buy
seriously
save yourself time and fatigue, it won't work
Stee said:thanks
in any forum there is someone that say however the same
Andy
- Super Sanken Final Stage "Tauro"
