Studio Reference Amplifier
sir mile
sir mile when i use ac 45-0-45 dc covert 63-0-63 but amp is not stable on 4ohm .in this form u say 65-0-65 dc is stable on 4 ohm .i just attach picture
my 10 ohm resistor burn .when i use 4 ohm.i hope u can help me
Hello sir
Hello sir.i attached picture which resistor is burn on 45-0-45 ac on 4 ohm.but when I drop ac volt like 30-0-30.then is working on 4 ohm .and resistor not burn. I hope u understand sir .thanks. It's 10 ohm
if you do an amplifier on my earlier files,you should pay attention on 2N5401 and his Hfe - it should be at least 250. is it enough you can check by measuring it´s Uce,it should be under 1V. if you don´t have it you can use another one,for example BC560C or BC516 but you must check pinout diference.
on files under this post there is PCB with BC516 placed instead 2N5401,and here is a part list for that version:
10r x6
47r x2
100r x3
1k x10
220r x9
2k2 x2
15k x2
22k x2
47k x1
100k x1
220k x3
360r (Rrel) x1
1r 2W x12
6k8 2W x1
4r7 2W x2
560r 2W x1
Relej x1
Osigurač-postolje x2 (FUSE)
LED 3mm x1
LED 5mm x1
2SA1943 x2
2SC5200 x2
MJE340 x2
MJE350 x2
2N5401 x1
2N5551 x3
2SC4793 x1
2SA1837 x1
BC516 x1
BC557 x2
BD139 x1
MPSA42 x1
MPSA92 x2
1N4007 x3
ZD15V x2
1N4148 x10
10pFx1
470pF x2
100nF63V x5
100nF100V x1
1nF63V x1
1uF 100Velk. x1
10uF50V-blok x1
100u25V x1
47u100V x1
220u25V x2
220u63V x4
470uF16V x1
What is A1 and A2 on pcb
