stereo chipamp channel separation
One could swap out the 100uF to become 1uF and then measure the F-1dB frequency when driving an 8r0 dummy load. See if it changes when testing into a 4r0 dummy load.
Then try 10uF and see if it does go down one full decade into both loads.
Is it reasonable to assume it would go down another decade when returned to 100uF?
zanden30 I think you are mistaking something really.
That cap is not even needed there I think.
The current comes from the driver chip, not through the resistor.
Ahh last page didn't come in yet.
But still don't know if the cap is even needed at all. Or it acts as filter.
i almost always use 4r speakers ,and have cheap transformers available local, but 28+28 or 30+30vac . i dont even aim for more than 5 amps out actualy
if this crap board up measures good,i will order few of boards on picture down and that should measure/work better
i expect better or same distortion, 100w output, 24/7 operation,all loads,4r work on relative high +-40v dc. oh yes and if needed only lm can be used with only place wire on place of resistor,so no need of different board and always can have components on stock.
sort of all i could/will need in one board and parts can be left out.
do i ask too much?
The LM3886 is capably of 0.005% distortion, pretty low.
The PSRR is excellent but you output stage has almost zero rejection meaning ripple will mix with the sound and create distortion. Your best move is to make a perfect pcb for the chip itself and to have proper decoupling and ground planes on the pcb. A critical spot when you have a pcb and power signals is the grounding scheme. A small mistake in the pcb can change the distortion from 0.005% to 0.1%.
NS specifies the thing for only 68W @ 4 Ohm.
The ChipAmp clips with 7A (see specs). If you are lucky @ 11A, but do not count on it. So you need the boost transistors!
P = I^2 x R = 49 x 4 = 196 W.
P RMS (sinus) = 1/2 of that so 98W. But you are working on the limits ==> boost really necessary for 100W with low distortion. Also for heat dissipation.
From the data sheet of the LM3886:
Over-Voltage Protection: The LM3886 contains overvoltage protection circuitry that limits the output current to approximately 11Apeak while also providing voltage clamping, though not through internal clamping diodes. The clamping effect is quite the same, however, the output transistors are designed to work alternately by sinking large current spikes.
The ChipAmp clips with 7A (see specs). If you are lucky @ 11A, but do not count on it..................
NS specifies these for a cold chipamp at 25°C and driving a resistive dummy load.
Those numbers reduce when the chip warms up and spike makes them even lower, particularly when the loading is reactive.
A warm 3886 driving a mildly reactive speaker load cannot pass adequate current to avoid current clipping of transients.
That's why one hears the 3886 becoming "loud" in a not nice way when compared to a 50W discrete power amplifier that is not current crippled.
here are measurments, i tested it with 4r speaker and machine headphones as i dont have big enough resistor for this
