SpeakerSim speaker simulation software
New version 2017-12-03:
  • New power handling simulation:
    • IEC 268-5 power is shown instead of linear power
    • "Pe defined at" parameter added to driver for tweeters (when power is defined with high pass filter)
  • Excursion simulated with IEC 268-5 filter
IEC 268-5 filter:
  • low pass 3dB filter at 0Hz
  • low pass 12dB filter at 5kHz
  • high pass 12dB filter at 40Hz
Thank you for reporting. I have tested it on Windows 7 (32 bit) without Java installed and it worked.
Please answer this questions to help me determine where the bug is:
  • Did you have Java installed?
  • If you have Java installed which version?
  • Did SpeakerSim try to install Java?
  • 32 or 64 bit Windows?
  • Does SpeakerSim.jar work?
  • Does portable (zipped) SpeakerSim work?
It's ok I downloaded the pack you provided and everything works fine now. I previously only used the win installer (.exe) Going to try this 😀
I just ran the Windows insaller package, set the environment altitude as 3 metres and got this error message;
java.lang.NullPointerException
SpeakerSim.PowerResponseSimulation.<init>(Unknown Source)
SpeakerSim.BassReflexSimulation.<init>(Unknown Source)
SpeakerSim.Speaker.refresh(Unknown Source)
SpeakerSim.Item.childrenRefresh(Unknown Source)
SpeakerSim.Item.refresh(Unknown Source)
SpeakerSim.PassFilter.refresh(Unknown Source)
SpeakerSim.GUI.MainWindow.refresh(Unknown Source)
SpeakerSim.GUI.MainWindow.menuEnvironmentActionPerformed(Unknown Source)
SpeakerSim.GUI.MainWindow.access$1400(Unknown Source)
SpeakerSim.GUI.MainWindow$41.actionPerformed(Unknown Source)
javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
javax.swing.DefaultButtonModel.setPressed(Unknown Source)
javax.swing.AbstractButton.doClick(Unknown Source)
javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
java.awt.Component.processMouseEvent(Unknown Source)
javax.swing.JComponent.processMouseEvent(Unknown Source)
java.awt.Component.processEvent(Unknown Source)
java.awt.Container.processEvent(Unknown Source)
java.awt.Component.dispatchEventImpl(Unknown Source)
java.awt.Container.dispatchEventImpl(Unknown Source)
java.awt.Component.dispatchEvent(Unknown Source)
java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
java.awt.Window.dispatchEventImpl(Unknown Source)
java.awt.EventQueue.dispatchEventImpl(Unknown Source)
java.awt.EventQueue.access$500(Unknown Source)
java.awt.EventQueue$3.run(Unknown Source)
java.security.AccessController.doPrivileged(Native Method)
java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
java.awt.EventQueue$4.run(Unknown Source)
java.awt.EventQueue.dispatchEvent(Unknown Source)
java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
java.awt.EventDispatchThread.pumpEvents(Unknown Source)
java.awt.EventDispatchThread.run(Unknown Source)
I would simulate it as Bass Reflex with stuffed port (low Qp and probably also low Qa).
I would also use port calculator for vent dimensions (or for number of Variovents).
To make it typical aperiodic enclosure set frequency to frequency of closed box at that volume. Simulation will show you typical aperiodic low impedance at resonance.
