Is there an online version of the course in " Davish"?
and to Chris, it's much harder than it looks to deliberately type something wrong. ( at least ofr the rest of us...)
between the simple misstipes and the intentional spontaneous reconstruction of English as she's spoke, that would be quite a challenge
once again, the presumption is made that deliberation (in the sense of situational awareness and attention to actual keystrokes) is ever a factorand to Chris, it's much harder than it looks to deliberately type something wrong. ( at least ofr the rest of us...)
it's actually scary to spend time with him in his own workshop - his other nickname is "Dangerous Dave" - let's just say the man goes through a lot of band-aids, and is living proof of the power of the human immune system to overcome flesh wounds . 😀
BVRs
My question is directed towards the original BVRs (Harvey , Iris , and Bruce had much longer ports than the new Changs. I'm wondering what is the audible difference between the old and new. Les Hudson
Dear sir: methinks this is where your otherwise flawless logic fails the reality test.
Fortunately for us all, "mrD" , a familiarity which my symbiot designation permits, has a robust sense of humor
Mr. B,
My exalted status as an Audio Aristocrat forbids me to enter into an arguement with one of the...sniff-sniff... "Crowbar Class." (It's a lot safer as well)
Best Regards,
Terry, The Third Earl of O
Mr. Hudson,
The original boxes were at least partly inspired by the Replikon, it had the apearance of a BLH, but used a large chamber behing the driver as an acoustic low-pass filter. Harvey, Iris, and Bruce were IIRC purposely designed to be less sensitive to driver parameters.
All of the Chang variants were designed for a specific driver.
I know you would like to hear a description of the sonic differences, but I cannot testify there, perhaps someone else would chime in.
Most of this info is found here:The Spawn Family of Double Horns
I hope this is of some use to you sir.
John
...his other nickname is "Dangerous Dave" - let's just say the man goes through a lot of band-aids, and is living proof of the power of the human immune system to overcome flesh wounds...
Mr. 10 describes himself as not belonging to the set "those who are allowed to use tablesaws" - I've always assumed the authority cited here is Ruth, but couldn't say for sure. 🙂
FE103AeN mounted temporarily in Aiko for evaluation. From listening for the last 10 days i'm going to say this is the best i've heard these and there is room for improvement as the install is a bit jury-rigged.
dave
dave
Just got Bruce double horns and i must say that it's an welcome improvement over regular box-speakers 🙂
I have only tested them with a Philips 9710m drivers, and i don't know how well they fit the cabs?
i can see that the topic has gone cold. but for me this is where it starts
should i expect big improvements with other drivers? and which drivers should i get then? -can't find the fostex recommended for Bruce.
would Audio Nirvana 8' be a good match?
the 9710's not bad at all, but i miss a little bas and then there is the curiosity.
jens
jens
Bruce was designed for Fostex FE207e
Pioneer B20 & Hemp Acoustics FR8c have been used as subs successfully. A single reort that AN10 worked (can't recall which AN10)
dave
dave
i'm planning to build a pair of the Hiro speakers, do i need to put some wool into them, or do they sound just fine without any damping?
Well, you know your own system, room & preferences: we don't. Best advice is really to use / adjust to your own requirements.
You play with damping in th air chamber bhind the drivr, Little if anything else should be needed.
dave
dave
thanks for the answers, so i'll try a little before i fix the side panel, when i'm done i post some pics here (if you want to see them)
Having built Saburos and playing with
cahamber dampening a lot,
This is what worked best for me
3/4 inch wool felt on front baffle behind driver,
also felt one side wall & top of Chamber,
I would think you would have the same results as I.
No dampening lets a lot of unwanted upper mids
find there way thru the horn openings.
Good Luck
Good Luck
- Full Range
- Spawn of Frugel-Horn
