Soundcraftsmen pm860 fan stuck on high speed
i have another pm860 that works fine. would it be a good or bad idea to pull it and try it in this amp?
BAD idea.
Avoid needlessly messing with that amp, any amp.
You have measured nothing pointing to a bad chip, it´s just a guess.
PAMPER THAT PCB, the ONLY unavailable part, can´t be bought over the counter,it´sunique, it´s what makes that amp that amp and nothing else, it is the single most important and most irreplaceable part in that amp, anything else can be bought over the counter or has equivalent replacements, need I to go on?
Desolder/resolder parts only if really needed.
As a side note, you have already damaged that amp by needlessly messing with it.
i just tried the chips from the other amp. same thing.
I told you: just a guess.
look at the power supply board the 2... lm4316 have already been swaped....with no success
BAD idea.
BAD idea.
the amp sounds fantastic. i realize the pc can easily be damaged. i have lifted a couple of traces simply by unsoldering. but i can jumper if need be
BAD idea.
these are socket chips , no soldering involved
BAD idea.
Ok, check the small parts as mentioned in post #40.
Hello, good day. after pulling the amplifier apart i found 50v dc on the positive pin that goes to the led light. after comparing it to the other channel the volts are close to zero. the grounds measure the same. I am sure the problem is on the positive side. R22 IS 3.3K RESISTOR and it looks burned,but still shows 3.3k ......some how i have too much voltage on +of the led
The clipping lights have nothing to do with the IC chips in there. It's likely Q8 is shorted. Q8 for each channel should be on the driver board on the front side of the heatsink near where the power wires plug on.
Ok, I did check Q7 and Q8 ... both seem to check out ok with my dac-55 transistor tester. I did notice that the 3.3k resistor near Q8 is chard. Would that cause a problem ? I measured the resistance and it does show 3.3k
